1 inc reading - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Lilpooh
post #1 of 10 Old 03-12-2014, 04:05 PM Thread Starter
1 inc reading
Hey I'm new to the forum. I have a "1 inc" reading. EGR. What does this mean and how can I fix it. Thanks.
350STOCKPSD is offline
post #2 of 10 Old 03-12-2014, 04:07 PM
ZMANN's Avatar
Quoted: 1771 Post(s)
can u elaborate ?
We Miss you Ronnie
ZMANN is offline
post #3 of 10 Old 03-12-2014, 04:11 PM Thread Starter
I plug the scanner into the truck. No codes and 1 inc reading. It's the EGR system. Idk how to make that system ready?
post #4 of 10 Old 03-12-2014, 04:53 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I have no idea what "1 inc reading" means. Just a FYI, not all scan tools can read code correctly. The scan tool your using might not read the EGR codes.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 10 Old 03-12-2014, 04:53 PM
ZMANN's Avatar
what scanner
i am not familiar with a 1 INC ??
that system doesn't have a ready state to test as far as I know
We Miss you Ronnie
ZMANN is offline
post #6 of 10 Old 03-12-2014, 05:13 PM Thread Starter
Sorry I should elaborate lol I have a 2007 350 6.0 PSD. I have a pocket scan scanner. It's nothing special. I plug it in and it reads 0 codes. 1 incomplete. And 2 ready. The incomplete is the EGR system
post #7 of 10 Old 03-12-2014, 06:25 PM
Powerstroke Techie
Lilpooh's Avatar
Might be the scanner, most cheaper scanners won't read manufacturer specific codes.
Heavy_GD likes this.
Lilpooh is offline
post #8 of 10 Old 03-12-2014, 06:45 PM
ZMANN's Avatar
i would sweat(late edit = would not=sry typo ) the 1 inc
that scanner wasn't going to initiate any tests on it's own
We Miss you Ronnie
ZMANN is offline
post #9 of 10 Old 03-12-2014, 08:54 PM Thread Starter
Yeah it's a cheaper one. I've had it for a while and just never used it on the truck before. Hoping you're right about the manufacturer specific codes. It reads the EGR codes on every other vehicle I've plugged it into but I know these PS's are a different animal. Only reason I'm worried at all is I just replaced the EGR valve. I wasn't sure if it needed to be programmed or something for a new one. This is my first diesel and I'm slowly becoming familiar with the ins and outs of this beast
post #10 of 10 Old 03-13-2014, 06:14 AM
ZMANN's Avatar
shoot I wouldn't sweat the 1 inc sorry for the typo
egr valves are plug and go
no programming and if the system had/ has a code it will self clear after a few drive cycles assuming the problem is repaired
We Miss you Ronnie
ZMANN is offline
