Engine Oil Pressure switch - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-24-2014, 10:50 AM Thread Starter
we bought a 2004 Superduty with a 24v and 5R110 2 years ago, mid swap. We P-Pumped it because we couldnt get it to run. then trans took a dump so were converting it to a ZF6.
I removed the ECM because its pointless at this point to have. The only thing the ECM would do is send the signal of oil pressure to the dash.
Does anyone know where the oil pressure switch wire is in the ford harness?
02 QCSB 6 Speed Ram|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair DD 3600|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"|Miter|Dana60/80|3:55|True Trac|35" Toyo MT's|
Rollin Coal02 is offline
