Pollack fuel selector valve Wiring - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-20-2014, 04:43 PM Thread Starter
Long story short! I bought a regency conversion 2006 F550 and have yet to get the aux fuel system to show fuel level on the gauge. There is no separate fuel gauge just factory. My question(s) are will it read out on the factory instruments or not? Valve itself seems to work best I can tell... I hear it when I hit the main/aux switch. Coming out of the Pollack valve is a series of wires some I understand what and where they go but one or two are wired into the factory harness on the frame rail. I do not know what else to check. I have been afraid to run the truck down the road on the aux setting just incase something is wrong and it's not getting fuel. As of now what ever level of fuel I have in my factory front and rear tank is all my gauge reads. If I switch it to aux it just shows the exact level of stock tanks..hopefully that makes sense to those that are reading this. I know it's not correct as I am guessing I have about 40 gals in the aux tank.
No brand name on the tank or anything other than the selector valve. Same brand that ford already had on it for the cab/chassis front and rear tanks.
Couple pics below
Jrod78 is offline
post #2 of 10 Old 02-20-2014, 04:46 PM Thread Starter
Pic 1.........
Jrod78 is offline
post #3 of 10 Old 02-20-2014, 04:48 PM Thread Starter
Seems I can't post more than one pic at a time sorry..May be operator error
Jrod78 is offline
post #4 of 10 Old 02-20-2014, 04:50 PM Thread Starter
Pic 3...........
Jrod78 is offline
post #5 of 10 Old 02-20-2014, 04:51 PM Thread Starter
Pic 4............
Jrod78 is offline
post #6 of 10 Old 03-28-2014, 01:52 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Where does the tank feed into? Does it feed the main tank?
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #7 of 10 Old 03-28-2014, 07:45 PM Thread Starter
No it feeds the main fuel line on the frame rail going to engine. Completely seperate from stock fuel system
Jrod78 is offline
post #8 of 10 Old 03-29-2014, 06:59 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
It probably is not hooked up to the factory gauge, but you could try and find the factory gauge wires and see if any of those wires are spliced into the factory wires. Also it would seem to me that if the tank had wires coming out of it those would be the wires that would send the signal to the gauge not the wires on the valve.
Shawn
Qholic is offline
post #9 of 10 Old 03-29-2014, 08:30 PM Thread Starter
Yeah it has wires coming out of the tank sending unit and another 5 or 6 wires coming out of the pollack fuel valve. Sending unit wires go up under dash as we'll. I'm just really unclear as to why it would tie in to the factory harness if it doesn't read out anywhere on factory instrument. It's puzzling to say the least. Guess it could be a traxxas fuel system and whoever just took the read out gauge..maybe
Jrod78 is offline
post #10 of 10 Old 03-30-2014, 10:59 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Are the sending unit wires up under the dash hooked up to anything that you can tell? If not could be there was a gauge mounted somewhere and then it was removed or never installed.
Shawn
Qholic is offline
