Single to dual alternator conversion? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-17-2014, 10:06 AM Thread Starter
07DIESEL6L's Avatar
Anyone done this on their truck before?
Any benefits to this instead of upgrading to high output alternator?
What parts would be required to do this conversion?
Sent from AutoGuide.com App
07DIESEL6L
Bulletproofed
RCD EGR Delete
Sinister Diesel Coolant Filtration Kit
Warren Diesel 175/Stock injectors
ARP Studs
H&S Cold Air Intake
Mishimoto Intercooler Piping Kit
5" MBRP Turbo back with 8" Tip
Stock Turbo with billet wheel
Innovative 58v Tuned FICM
Tuning by IDP
07DIESEL6L is offline
post #2 of 2 Old 02-17-2014, 05:38 PM
Quoted: 57 Post(s)
It's not as easy as one would think. The dual alt 6.0s have two belts, two tensioners, two idler pulleys, and a different hot side CAC tube and engine wiring harness. The PCM also needs to be flashed to make the second alt work. Unless you can find a donor motor with dual alts, it would faster, easier, and cheaper to install one of the larger DC Power alts. Then do the Big 3 battery cable upgrade and you will be all set
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
