wiring in AUX to a 3.5mm headphone jack - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-12-2014, 09:21 PM Thread Starter
I have a stock ford stereo that has the aux button, and I am trying to wire it into a 3.5mm female port to mount to the dash, I found a wiring schematic, and I wired it as I thought would work, but nothing. Anyone know more about car audio help me?
I wired the Right + on the stereo to the Right on the 3.5mm jack, and same with the Left +, and on the Right and Left- I ran them together to the ground on or common on the 3.5mm jack, anyone know why this doesnt work. I dont want to spend $100 on a aftermarket part if I can do it for $2.69 at radio shack.
I included three pictures, first is ford wiring diagram, the middle input is what I am trying to wire to, notice the Stereo R+ and R-, and the L+ and L-,
second pic is the radio shack 3.5mm plug, the diagram is for a different application but should be the same I am using connection 5 and 2 for left and right and the 1 for grounding both from the R- and L- together.
Last pic is just one that I found online, is basically what I am trying to do
ID:	242258   Click image for larger version
ID:	242274   Click image for larger version
redeye_joe is offline
post #2 of 3 Old 03-17-2015, 12:10 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
Annnnnnd.... did it work?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 3 Old 03-17-2015, 05:56 AM
Bocephus80's Avatar
Use this. Makes it easy. There's a video on youtube for the install.
PIE Precision Interface Electronics FRD04-AUX Auxiliary Input interface adapter for most 2004-2008 Ford Lincoln Mercury CAN-Bus Radios EnfigCarStereo.com
iSimple IS335 EnfigCarStereo.com
2007 F250 C.C. L.B. 4x4
Blue Spring, Scangauge II, Riff Raff boots,
XDP coolant filter
Bocephus80 is offline
