04 6.0 f350 PCM pinout help - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-11-2014, 06:31 PM Thread Starter
Can someone help me find a PCM pinout for a 04 6.0?
2004 F350 6.0 FX4 Lariat Crew Cab Short Box SRW Egr Delete, ARP Studs, Coolant filter, Edge Juice with Attitude, Blue Spring Fuel Upgrade, Banjo Bolts, Straight Pipe Exhaust, 19X,XXX
partsmark72 is offline
post #2 of 12 Old 02-12-2014, 03:19 PM Thread Starter
Help!!! Anyone Need this to move on with my project
post #3 of 12 Old 02-12-2014, 03:33 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Does this help?
Pin out for the middle plug on the pcm for 6l - TheDieselGarage.com
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #4 of 12 Old 02-12-2014, 03:34 PM
Quoted: 4 Post(s)
And maybe this thread?
Upfitter Switch as Ignition Switch/Relay?? - Page 2 - Ford Truck Enthusiasts Forums
post #5 of 12 Old 02-12-2014, 03:34 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
You can try the coffeetable book..it may help..
http://www.forddoctorsdts.com/downlo...eTableBook.pdf
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 12 Old 02-12-2014, 03:52 PM Thread Starter
I need the plug Closest to the firewall.
post #7 of 12 Old 02-12-2014, 04:13 PM
Quoted: 4 Post(s)
What are you looking for on that plug? 2 are the same size, one is smaller from what I can see.
post #8 of 12 Old 02-12-2014, 05:13 PM Thread Starter
I am looking for the pin out on the large connector closest to the firewall. My truck had a burnt spot on the plug so I need to know what I need to fix. Truck will not turn over and the fuel pump does not come on. The dash lights up and the glow plug light comes on and then when you go to start it nothing happens. I also cannot connect to the pcm with my solus pro. I have ordered a used pcm but need to repair the harness to get it going again. Need the pin out to know what the burnt pins do. It is the body harness connector not the engine one.
post #9 of 12 Old 02-12-2014, 05:25 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
Try this.... it's for an 05 but I bet it would be almost identical...
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
The Following User Says Thank You to anschutz1913 For This Useful Post:
partsmark72 (02-12-2014)
post #10 of 12 Old 02-12-2014, 05:49 PM Thread Starter
That's it Thank You
