Emergency light ? (wig wags) - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-07-2014, 10:30 PM Thread Starter
Iv been giving the go ahead to get wig wags for my truck(vol firefighter) but Iv been doing research and when I look at headlight flashers theres basicly two kinds. Positive switch and ground switch. Does anyone know what our system is? Oh, its a 2006 f350. Iv also been looking at ones to put in the grill. Now Im not looking to go "wacker" and not going to spend 200 bucks on something but these are some other options iv been looking at.
Nova Flash 1 Headlight Flasher
S86 4 Lights LED Police Strobe EMS ATV Clear Amber | eBay
705 4 White Clear LED Strobe Light Wig Wag EMS Fire Constuction Lights | eBay
Federal Signal 656101 FP1 Ford CV 2004 05 Plug N Play Headlight Warning Flasher | eBay
Idealy Id like to hook them up to one of my auxillary switches if possible. Anyone have wig wags? Its the only lights we can use in delaware
06 F350 KR / 12 sprinter 323bhs
tomsws6 is offline
post #2 of 8 Old 02-08-2014, 11:01 AM
mikegoslin09's Avatar
Try sppedtechlights. That's where I got my light bar. A little pricey, but the quality is superb. Brightest lights I have seen. Most have a 12v lead so you can tie right into a fuse.
2004 F350 6.0L Powerstroke FX4
72,000 miles and climbing
4" MBRP turbo back to 6" stack
SCT SC3, tunes from Eric @ Innovative Diesel
Edge Insight CS
GlowShift Boost, Fuel Psi, 2400* EGT gauges
Blue Spring Mod
Zoodad Mod
Venom Wheel 2" spacers
Still running Ford Gold with great deltas, good coolant pressure. Healthy truck.
mikegoslin09 is offline
post #3 of 8 Old 03-07-2014, 10:50 AM
Powerstroke Tech
whitestrikr21's Avatar
Quoted: 3 Post(s)
Garage
i know the 03 superdutys are positive switching which will require the whelen posuhf for the flasher. just in some advice I would look into going with whelen vertex leds. Super bright and effective. I would also recommend staying with the whelen brand used some of the cheaper brands and it just didn't compare
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
XDP egr delete
whitestrikr21 is offline
post #4 of 8 Old 03-07-2014, 11:54 AM
sabarnes's Avatar
Do yourself a favor and use a secondary light for the front wig wags and not your headlights. Our fleet goes through head lights like there's no tomorrow because they are set up for the wig wag. Adding a white light intended only for the wig wag function is a little more work but well worth it. Besides running code 3 with your lights constantly changing from low to high beam at night is horrible for the driver and the on coming traffic.
sabarnes is offline
post #5 of 8 Old 03-07-2014, 12:20 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Get yourself a Solid State Relay wig wag set up.
Preferably one that flashes at a rapid pace so the bulbs don't have a chance to go completely off... That will save your bulbs.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 8 Old 03-13-2014, 01:34 PM
positive switching vs negative switching is simply how the switch operates. positive switch uses a switch that interrupts the power before going to the accessory, when used it allows power to flow to it then to ground.
battery power - switch - light - ground
negative switches are wired so that the switch is between the ground and the accessory so that it cannot complete the circuit to ground until you hit the switch.
battery power - light - switch - ground
both have their pros and cons but essentially complete the same job.
kornfanjoe is offline
post #7 of 8 Old 03-28-2014, 09:06 PM
I did something similar but didn't go with the wig wag setup. I did an interior light bar in the front, led hideaways all the way around, 8 head led stick in the rear and some surface modules. I got everything from CPS Authority Emergency LED Warning Lights . They had great prices compared to what I was paying before and are super bright. They got a video of my truck on the website. I'll try to post it up.
hydrohopper is offline
post #8 of 8 Old 03-28-2014, 11:49 PM
