LED light bar to replace the factory fog lights - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 24 Old 02-05-2014, 05:00 PM Thread Starter
freeride808's Avatar
Seeing if anyone has done this. I have an 04 KR with factory fog lights that I want to put a 20" Rigid E2 light in place of, but keep the function off of the fog light switch. The factory fogs are 35 watts per or 70 watts for the set. But the 20" bar is 150 watts or 9.5 amps.
I would rather not have to do a relay but may have too. Any input is appreciated.
2004 F-350 DRW KR, Half Spartan/ Half Elite Motor with custom internals, 155 injectors from Warren),Elite VGT-SS Turbo (now it is a paper weight ) replaced with Power Max, ITP RR, Airdog II adj, Banks CAC tubes and intercooler, Amsoil Bypass oil filter, Elite EGR Delete, Elite Head Studs, AFE Stage 3 intake, 4 exhaust
freeride808 is offline
post #2 of 24 Old 02-10-2014, 05:05 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1706 Post(s)
Feedback Score: 4 reviews
Yep, a lot of people have done this and BPD sells a mounting kit to make it all bolt in easy. There may be another kit, but I don't recall right now
Either way, you'd probably be fine running that power through the stock wiring, but I say better safe than sorry and do one anyways.....the stock wiring to the fogs is a joke and a relay upgrade kit is pretty easy to build. I built one for my lights in my bumper (Lightforce 140s) that retains the fog light switch function to turn them on. The switch just triggers the relay and sends lots of juice to the lights......there's a spot behind my front plate that's getting a 10" E2 when I get the $$$......Please post some night pics when you get that 20" in there
Stiles likes this.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
The Following User Says Thank You to nighthawk285 For This Useful Post:
freeride808 (02-10-2014)
post #3 of 24 Old 02-10-2014, 08:32 PM Thread Starter
Thanks for the heads up on the BPD items. I just ordered that and the factory plug and play connector.
On a side note I live in Portland but spend a decent amount of time up on Mt Emily. I see you are just over the hill. Also what bumper is that that you have?
Baron
post #4 of 24 Old 02-10-2014, 09:05 PM
You live in Portland but spend time on Mt. Emily??? Like the one just above La Grande, or is there another one I'm not aware of?
It's a Fusion, built in Payette, ID. http://fusionbumpers.com/
If you're over in my neck of the woods, it's always cool to meet another Org member
post #5 of 24 Old 02-11-2014, 10:59 AM Thread Starter
Have hunting rights down in Duncan and most of Black mountain, Meacham Creek. Long drive but good change of pace from Portland.
Should have the light in hand later this month. It was a 2-3 week lead time.
Hit me up on face book, Baron Adams
post #6 of 24 Old 02-11-2014, 11:29 AM
Heavy_GD's Avatar
Quoted: 1440 Post(s)
Feedback Score: 3 reviews
These guys make direct bolt brackets for the stock location:
dirtydiesels dot com
Stiles likes this.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #7 of 24 Old 02-11-2014, 11:34 AM
layson's Avatar
Quoted: 82 Post(s)
LOL, I was born and raised up by Meacham. LOL
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #8 of 24 Old 02-21-2014, 01:01 PM
Run it through a relay for sure...just to be safe. I've got mine on a separate switch for now, might move it over to the OE switch.
KD Fabworks has brackets for the 99-07 trucks, and in Portland, OR as well.
Stiles likes this.
02 F350 7.3L Lariat; DP tuner, AFE stage II intake, AFE intake manifold, dual 4" exhaust, ATS trans, Autometer gauges, Superlift 8",
38" Toyos, 20" Provo's, Amp Powersteps, 05-07 Front end Conversion, KDfabworks bumper bracket with CSI 20" LED....
kjdavis is offline
post #9 of 24 Old 03-04-2014, 11:54 AM
A couple night shots of mine:
The brackets:
kjdavis is offline
post #10 of 24 Old 03-04-2014, 01:21 PM
Fantom's Avatar
Quoted: 12 Post(s)
Do you have any pics of how it mounts? I'm wanting to do a lightbar in place of my factory fog lights.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
The Following User Says Thank You to Fantom For This Useful Post:
03 6.oh (12-04-2014)
