NO HEAT! FREEZING HELP! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-05-2014, 07:38 AM Thread Starter
not sure if this thread belongs here. i have an 03 f350 PSD 6 speed. last year my heat worked no problem. this year, FREEZING! the heat only kicks on if im on the freeway with the engine revd up. i dont understand? is it something to do with the vacuum? idling and im my way to work, im numb. this is not enjoyable... please any suggestions are helpful. thank you.
strokindavis is offline
post #2 of 5 Old 02-05-2014, 07:46 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Check your coolant level...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 5 Old 02-05-2014, 08:10 AM
Quoted: 2 Post(s)
You've got air or a gas (not fuel) in the system. It can only come from a few places, but unfortunately, the most common source in a 'no heat' situation is combustion gasses from blown head gaskets. A bad degas cap or coolant leak somewhere will contribute to it as well.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #4 of 5 Old 02-08-2014, 03:23 PM
john galt's Avatar
Quoted: 1094 Post(s)
I have always read that is a sign of HG trouble as well.
Here is hoping you get lucky and it is something like vent doors not opening propperly
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #5 of 5 Old 02-08-2014, 03:41 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
I have had the same problem as well. Came from a coolant leak and found coolant was low. So check your coolant
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
