Edge CTS Turbo timer with Ungo SR7000 security system problem - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-01-2014, 02:20 PM Thread Starter
daehawc's Avatar
I've been searching but havent came across this issue yet.
I have a 2005 F250 with an Ungo SR7000 security sytem / remote start installed. The system does have the option for a turbo timer if you press some buttons before turning off the truck but I wanted to set it based off of EGT so I added the EDGE CTS universal turbo timer.
Edge turbo timer works properly but if I arm the security system while the turbo timer is running, when it shuts off it disarms and unlocks the truck. I have disabled the Ignition Off unlock feature from both the Ungo system and the ford system and confirmed it doesnt unlock any other time unless the turbo timer shuts off the truck.
Right now the only solution has been to put the system in passive arm mode and manually lock the doors when I walk away. This keeps the truck locked until the turbo timer shuts off and then the system arms 30 seconds later. Not ideal but better than an unlocked truck when I walk away from it.
Anyone have any experience with this problem and possible solutions? Thanks for the help.
daehawc is offline
