block heater need fix tonight! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-29-2014, 06:39 PM Thread Starter
Bashby80's Avatar
So my 05 block heater is tripping the GFCI outlets in my garage (first time for two years). I did some research to test my B.H. plug, got 15 OHMS on my meter, so that says GOOD! I went and bought the correct extension cord (12G/15Amps/25 ft) and it's STILL tripping the darn plugs.
I have 3 outlets in garage and one on my porch tied into a 20 amp breaker w/ one plug being GFCI, and one GFCI as a stand alone (not sure where it's tied into). It trips both of them after about 5 seconds of being plugged in after a long rest, and immediately after hitting the reset button each time.
Any help? I'd really love to have this fixed tonight if possible!
2001 dodge 2500 cummins 178k miles *sold*
2005 ford f250 6.0 Powerstroke Lariat FX4
20x10 Eagle Alloys (2.5 pro comp lift to be installed)
69k miles at purchase
Edge Insight CTS (w/ pyro)
Blue Spring w/ gauge on steering colmn
SCT X3 w/ Looney Tunes
5" dual miter stacks straight piped
Sinister coolant filter
High idle mod AUX4/Back up cam AUX3
Bashby80 is offline
post #2 of 5 Old 01-30-2014, 05:07 PM Thread Starter
Bashby80's Avatar
Well, it fixed itself.
Bashby80 is offline
post #3 of 5 Old 01-30-2014, 05:12 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Check yer block heater cord... I have had to repair 2 of them this winter... cord broke at the cordend. If its breaking it could cause gfi to trip. Broken insulation on the wire shorting to ground wire or truck intermittently. As an electrician I have seen it before.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #4 of 5 Old 01-30-2014, 05:46 PM Thread Starter
Bashby80's Avatar
Cord is good. No cuts or frays. Had good Ohm resistance. I think it was ice build up on the heater cord on the motor. Everything works now.
Bashby80 is offline
post #5 of 5 Old 01-31-2014, 04:14 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 104 Post(s)
Feedback Score: 3 reviews
Remove the cord from the heater element in the block, spray and clean the connections (plug and cord), use a good dielectric grease when plugging the cord back into the heater element.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is online now
