No Brake Lights - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-29-2014, 05:11 AM Thread Starter
tinygiant's Avatar
No Brake Lights
All,
Electric once again on the old X. All lights work as advertised except the brake light (all three). Brakes work fine. There is also no signal going to the brake controller (controller does show a 'c' for connected) and brake lights on attached trailers are inoperative. All other functions on both the truck and trailer (running lights, 12v, blinkers, reverse, etc.) work fine.
There are no blown fuses anywhere in the panel. I replaced both #18 and #28 as they are marked as brake pedal position switch fuses (neither was blown). All connections are tight and no connectors are corroded.
I haven't gotten to testing Pin 5 on the BPP harness just yet as it's a tad bit chilly outside and the kids are not in school today.
Any other ideas? I couldn't find anything like this in the search.
Thanks,
..ed..
___|0o0|___
'04 Excursion PSD (Hers)
'03 F-350 PSD (His)
'05 BMW 325i (Her Daily Driver)
'08 Harley Davidson Fat Bob (His Daily Driver)
'79 Fairchild Republic A-10C
tinygiant is offline
post #2 of 5 Old 01-29-2014, 08:04 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
Check brake light switch for power in ,then depress pedal should be power going out when depressed .thats where I would start !!!
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is offline
post #3 of 5 Old 01-29-2014, 08:06 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
Switch is on brake pedal arm above your foot !! Had this problem on another truck ( wire was broke in plug )
s:
Pro fuzz is offline
post #4 of 5 Old 01-29-2014, 09:59 AM Thread Starter
tinygiant's Avatar
Thanks. Heading out to check it now.
..ed..
___|0o0|___
'03 F-350 PSD (His)
post #5 of 5 Old 01-29-2014, 11:37 AM Thread Starter
tinygiant's Avatar
Sometime it's nice to have that second 6.0L vehicle hanging around. I swapped the BPP switches and, ta-da, the brake lights worked just fine. Took the original switch apart and found that the "nub" on the spring between pins 4 and 5 had detached itself from pin 4 spring and permanently welded itself to the pin 5 spring. Resistance between the two pins when contacted is infinite. Good news is that Auto Zone sells the original Ford part for 12 bucks. The dealer wants almost 30.
..ed..
___|0o0|___
'03 F-350 PSD (His)
