Low beams coming on when High beams activated? HELP - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-23-2014, 03:44 PM Thread Starter
ktyamaha36's Avatar
Hey guys.
Leaving work today had a weird issue happen. When I turned my headlights on I noticed the blue high beam light lit up on my dash. But no headlights? only parking lights.. When I push the lever forward to activate high beams, my low beams then turned on and the high beam light on the dash went out.... Its as if the low/high beams have reversed lever positions. But the high beams do not come on.
Any idea on where to start here?? Has anyone experienced this before?
Thanks for any input!
2005 6.0 CC SWB 4x4
EGR Delete
4" MBRP Turboback Exhaust, No Cat, No Muffler
S&B Intake
SCT Tuned by IDP & Vivian
Sinister Coolant bypass filter
Updated STC Fitting
Blue Spring upgrade
EDGE CTS
9" Lift,
PMF Long arm 4-link kit
Pro Comp Traction Bars
Dual Steering stabilizers
Dual Fox Resi's in the front
20x12 Moto Metal MO962 wheels
38" toyo's
ktyamaha36 is offline
post #2 of 4 Old 01-23-2014, 05:45 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1816 Post(s)
Feedback Score: 4 reviews
probably the multi-function switch starting to die out on you (the one for brights, blinker, etc....)
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, KC S2R Ball Bearing Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 4 Old 01-23-2014, 06:32 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Are they stock headlights or an HID conversion? If it's a conversion, whoever installed them possibly have the Hi/Low wires reversed and the kit could be a low beam only.
dhanna6powerstroke is offline
post #4 of 4 Old 01-24-2014, 10:12 AM Thread Starter
ktyamaha36's Avatar
Thanks for the tip. They are stock headlights. They have been working normal until yesterday leaving work. Looks like I will be getting the multi function switch replaced and hope that takes care of it!
2005 6.0 CC SWB 4x4
EGR Delete
S&B Intake
Updated STC Fitting
Blue Spring upgrade
EDGE CTS
9" Lift,
38" toyo's
