Upfitter wiring check - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-11-2014, 10:47 AM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
Hi,
I hooked up two pair of KC lights on my truck using the upfitter switches. I used the red and the black wires. The lights on the black wire are fine but the lights on the red wire don't work. I swapped fuses and relays with the working lights to see if it made a difference. It didn't. So how do you check the red wire under the hood to find out if you're getting juice? I'm not too electrical smart so talk in laymen terms. I do have a meter. Thanks.
2007 F-250 Lariat PSD 6.0 4x4 Crew Cab
FordPSD6.0 is offline
post #2 of 4 Old 01-11-2014, 11:23 AM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
The red, black, blue and white wires are just pass through wires. What switches did you wire them to?
wvrrcarknocker is offline
post #3 of 4 Old 01-11-2014, 11:35 AM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
I wired the pass thru's to the 30 amp upfitter switches. Orange/lt green upfitter wire to pass thru red and orange upfitter wire to black pass thru. The lights on the black wire are fine. It's the red pass thru I want to check for voltage under the hood and work from there. I might not have made a good connection under the dash because it was so stinkin tight under there.
post #4 of 4 Old 01-11-2014, 11:39 AM
Quoted: 2 Post(s)
I'd check your connections again. That really sounds like the likely issue, as the rest is factory.
