pillar guages - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-10-2014, 01:59 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
pillar guages
Found this on a local facebook swap n shop type page.
A couple of question's, they said it was in a 2001 f250. Will it work in a 05 f350?
Will it work if I have my Edge monitor on the dash or will the bottom guage get in the way?
They are asking 145obo. Im guessing I could get it for 110-120.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 9 Old 01-10-2014, 02:08 PM
RADIOFLYER's Avatar
From what I can gather, 99-07 superduty's all use the same pillar. Is your edge on a dash pod? Or on a window suction?
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
RADIOFLYER is offline
post #3 of 9 Old 01-10-2014, 02:29 PM
Koda22's Avatar
Quoted: 5 Post(s)
Yea like said above the pod should work, and I would think the gauges would work too...but if you edge in mounted to the dash, I don't think it's all gonna fit...
Koda22 is offline
The Following User Says Thank You to Koda22 For This Useful Post:
Bad87tbird (02-25-2014)
post #4 of 9 Old 01-10-2014, 02:36 PM
RADIOFLYER's Avatar
X2...because those dash pods set them back a little bit and that bottom gauge hole is down pretty close to the dash IIRC
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
post #5 of 9 Old 01-10-2014, 05:48 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Sorry for the delay guys I stepped away from the computer for a moment. My Edge has a dash mount. That's kinda why I was concerned if the 2 would work together.
And after checking out Amazon Im not so sure this is a super deal after all.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 9 Old 01-10-2014, 07:28 PM
Koda22's Avatar
Quoted: 5 Post(s)
Personally can't tell wat kind of gauges they are so can't help there...but as for the edge..I've got mine above the rear view mirror...love the looks easy to see...and allows me to have a quad pod on the a pillar...
Koda22 is offline
post #7 of 9 Old 02-04-2014, 03:02 AM
Quoted: 8 Post(s)
I'm moving mine there today. It looks to me like the mirror needs to be relocated a little lower. Did you have to do this?
2005 Excursion Lariat 4x4
Mishimoto coolant filter, RCD EGR delete, '03 turbo w/ single plane billet compressor wheel, Edge CTS w/ EGT probe, 5" Rough County suspension, Hellwig 32mm sway bar, 35x12.50 Toyo M/T, 20x12 Fuel Renegade D263 wheels
Originally Posted by F450Harley View Post
I really believe these trucks have adaptive behaviors to your driving habits. Your truck reflects you.
If you think your truck might let you down…………..it WILL.
6literdiesel is offline
post #8 of 9 Old 02-04-2014, 04:58 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Do you have to run a cable extender? With the dash mount I just dont like how visible it is, so a mirror mount might be the way to go.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 9 Old 02-04-2014, 09:43 AM
Quoted: 8 Post(s)
Yes, you'll need the CTS cable extender. It runs about $45 or so after shipping. Below is the picture I found that inspired me to go with this set up, but as to my question you can see that his rearview mirror is pointed down to be able to clear the CTS. I'm not sure if he figured out a solution or if he did what I'm thinking and just relocated the mirror down an inch or two.
