Rear panel speaker removal with pics! - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ZMANN
post #1 of 5 Old 01-01-2014, 09:01 AM Thread Starter
So I saw a lot of people asking questions about how to remove speakers on crew cabs or vehicles where the speaker is located in the rear panel rather than the rear door. From most of the write ups I saw it was real easy to do, but I thought I would take some pictures for people just so they have a mental reference. So here it goes.
Step one: Clean out the back of your truck. (image 1)
Step two: Bring down the rear bench. (image 2)
Step three: Get a T50 socket, sorry that its a little hard to see with the glare.
Than locate your seatbelt thing, pop open the cover on it and this is where the torx bolt is.
Remove that bolt and lay your seatbelt on the ground for now.
(image 3-5)
Continued in next post so that I could add more images
Name:	2014-01-01 09.00.52.jpg
ID:	220658   Click image for larger version
Name:	2014-01-01 09.23.26.jpg
ID:	220666   Click image for larger version
Name:	2014-01-01 09.23.42.jpg
ID:	220674   Click image for larger version
Name:	2014-01-01 09.24.00.jpg
ID:	220682   Click image for larger version
Name:	2014-01-01 09.24.09.jpg
2003 F250 SuperDuty 6.0
and.decarlo is offline
post #2 of 5 Old 01-01-2014, 09:03 AM Thread Starter
Step four: Remove the little step thingy that is on the ground right when you open the door, it has three clips, so just pull it straight up. (image 1-2)
Step five: Remove the black rubber strip around the working area of the door. (image 3)
Step six: Remove the panel from the side, this is held in by 7 or 8 clips and can be a bit awkward to try to pull on, just try to make sure that you pull it straight out as much as possible. Once you get it off, lay it on the ground out of the way of your working area. (image 4)
Now you have access to your speaker (image 5), which is held in with four small bolts just like the front speakers. Re install everything in the opposite order. Hope this is helpful for you!
Name:	2014-01-01 09.26.08.jpg
ID:	220698   Click image for larger version
Name:	2014-01-01 09.26.53.jpg
ID:	220706   Click image for larger version
Name:	2014-01-01 09.27.27.jpg
ID:	220714   Click image for larger version
Name:	2014-01-01 09.29.51.jpg
ID:	220722   Click image for larger version
Name:	2014-01-01 09.30.08.jpg
post #3 of 5 Old 01-01-2014, 09:26 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
Nice job
let Me supplement with this PDF from Crutchfield
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
knuckledragger5 (08-17-2014)
post #4 of 5 Old 01-01-2014, 09:27 AM Thread Starter
Oh man, this is a nice document, didnt know it existed. Thanks!
post #5 of 5 Old 01-01-2014, 11:27 AM
ZMANN's Avatar
Crutchfield might Be a few bucks more but they sure earn it IMHO
they sent those to Me for free when I swapped My deck I bought from them
from My GM To my Ford = lifetime support
DAS3304 likes this.
We Miss you Ronnie
ZMANN is offline
Tags
speakers
