Headrest Monitor questions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-28-2013, 02:30 PM Thread Starter
mustangcobrajc's Avatar
Question Headrest Monitor questions
Hey, i have these monitors in the headrest of my truck when i bought it, but of course they dont work. I just wanted to see if any of you guys have worked with these before and know what i would need for them to work or am i just crap out of luck with non working monitors in my headrest. I know that i need a DIN Cable, 8 pin for both but i dont know where they run to and navigation cable if needed or want. And then a 3 pin ext. pwr cable but idk where it would run either.
ID:	219210   Click image for larger version
ID:	219218   Click image for larger version
mustangcobrajc is offline
post #2 of 6 Old 12-29-2013, 12:12 PM
seanol's Avatar
From what I can tell the unit is a standalone av monitor. You will need the av box that goes with it, the din cable connects the screen to the av box, and a separate nav box and cable for that.
You would need a power plug as well. You can get this from Alpine, they are on the web. If they did work at one time you should see the power and din cables in the opening through the seat. I would bet that everything is installed in the center console. Underseat mounting is possible depending on how shallow, and there is always behind rear seats. If you find the connections we can troubleshoot from there.
Hope that helped,
Sean
seanol is offline
post #3 of 6 Old 12-29-2013, 12:29 PM Thread Starter
ok. i will go out today and look and see if maybe i can find something for it...(Fingers crossed)
Update: Well i just went out and took both monitors out and i dont see any cables at all or any boxes in either center console or under the seats. So either they never finished the job or some reason took out all the parts for it.
05 F350 Harley CCLB 6.0L
SOLD!!!
General Grabber AT2 315/75-16 w/Newton 2.5" Level
5" Diamond Eye Turbo-back Straight pipe
Garret Stage 1 Turbo, ARP head studs
Sinister EGR delete, Sinister Coolant Filter
High Idle, CCV MOD to atmosphere
Blue Spring
Mag-Hytec trans pan and Diff cover
SCT Livewire 5015 custom tuned by Quicktricks
post #4 of 6 Old 12-31-2013, 04:27 PM
seanol's Avatar
You can always contact Alpine on the Web. 8" screens are a nice addition if the parts aren't too bad.
Good luck,
Sean
seanol is offline
post #5 of 6 Old 12-31-2013, 05:23 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Off topic but can you post pictures of how they look in your seats? I have a flip down and am not crazy about it. Would like to install these
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #6 of 6 Old 01-03-2014, 12:36 PM Thread Starter
hey sorry i took so long to get back, but here are what they look like.
ID:	221626   Click image for larger version
ID:	221634   Click image for larger version
SOLD!!!
Blue Spring
