Ham/CB Radio Installs - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-27-2013, 10:19 AM Thread Starter
05F350Lariat's Avatar
Does anyone have a Ham radio and/or CB radio installed in their truck? If so could you post some pics of how you mounted both the radio(s) and antenna(s)?
2005 F350 Lariat CC LB 4x4
SCT Livewire with EGT Probe, IDP FICM Programmer, 175/30 Renegade Diesel Injectors, ARP Head Studs, EGR Delete, STC Fitting Upgrade, Turbo Oil Feed/Return Line Upgrade, Blue Spring Kit, BullyDog CAI, Accufab Intake, FS2500 Oil Bypass Filter, Coolant Bypass Filter, Mean Green HO Alt., IDP Long Y Pipe, MBRP 5" SS Turbo Back Exhaust.
05F350Lariat is offline
post #2 of 17 Old 12-27-2013, 02:14 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
Start with the following:
Master CB thread
A lot of great info and advice throughout.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 17 Old 12-27-2013, 11:07 PM Thread Starter
Thanks! I guess I was looking in the wrong area for a thread like this.
post #4 of 17 Old 01-08-2014, 09:05 PM
Quoted: 3 Post(s)
You could do something like this...
What did you do with your Bag Hook?
As for antennas...
Tri-band VHF/UHF/800 NMO antenna for the scanner mounted on the forward right fender.
VHF 1/2 wave NMO antenna for the VHF radio mounted mid-way on the right fender.
Dual-band VHF/UHF NMO antenna for the V/U side of the IC-7000 mounted on the forward left fender.
VHF 5/8 wave NMO antenna (cut for 6m) for the HF/6m side of the IC-7000 mounted mid-way on the left fender.
GPS for the scanner is tucked up on the dash by the windshield.
Cheers!
Lee
ve7fet is offline
post #5 of 17 Old 01-08-2014, 11:30 PM Thread Starter
That looks pretty impressive! Not quite sure if I like it or not though.
post #6 of 17 Old 01-09-2014, 12:57 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
I got a RCI 2950DX running to a Wilson 5k thru the roof. Talks plenty far and clear with an excellent SWR.
I got the 40/20/40 up front. I took a piece of diamond plate from Tractor Supply, bent it in a few places, drilled holes, mounted it to the 20 section seat. I'll post pics later tonight.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #7 of 17 Old 01-09-2014, 05:27 PM
I was just looking at my truck today to see where to mount my cb, I have no clue either, lol.
i'm going to have to build something on the center hump,
I've got a galaxy 959, and it is about 1.5" wider than a standard CB, and about 0.5" taller, with a side mount mic....
here is a pic I found online next to a cobra..
fordtrucknut is offline
post #8 of 17 Old 01-10-2014, 03:31 AM
N.S.D.Q.
Quoted: 97 Post(s)
Bungee cord was for the fit test. It's all hard mounted now. I bent the diamond plate as I went along. Then I marked and drilled holes to mate it to the bottom of the center seat. Sits low enough that it;s not in the way, I can easily reach the controls, and I hang the mic off the overhead cubby.
post #9 of 17 Old 01-10-2014, 01:50 PM Thread Starter
Here are a few pics of what I ended up doing.
post #10 of 17 Old 01-10-2014, 04:28 PM
Quoted: 2 Post(s)
I did a little cutting on the overhead console.
2007 F250 Lariat FX4 CCSB
200,000+ Miles
SCT Livewire TS
Innovative Xtreme Street
Barder Stg 1.5
Arp Studs, Sinister EGR Delete
cudakid03 is offline
