PAC interface control wiring help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-27-2013, 12:04 AM Thread Starter
Superblazin's Avatar
Installing a new system in the truck and picked up a swi-rc. To interface with the steering wheel controls.
The PAC website is down right now and I can't find which wire on a 2005 to connect the white wire to?
Also I don't know how to program it.
Thanks in advance
__________________
2005 Harley Edition CCSB, 30 over mahl pistons, delipped, bowled and coated, Carrillo rods, colt stage 2 cam, studs, a little head work, Custom intake, redneck compounds 66- s480, No limit intercooler piping, Elite diesel ZZ max intake manifold, 205cc /100% injectors, 150/150 Fass fuel pump, Regulated Return, Hellmans sump, CCV relocate, NADP Tranny, PhP ficm tune, Innovative Diesel custom tunes and some Redneck Lovin
Superblazin is offline
post #2 of 3 Old 12-28-2013, 01:08 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
I believe it's the red/green one. The instructions should tell you which wire for the F series. Mine did, just be sure to solder the connection because it uses resistance values to operate the volume and next/mode settings.
As far as programming goes it's automatic once it's powered up.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 3 Old 12-28-2013, 02:44 PM Thread Starter
Still kickin my butt on this install!
Instructions were pin 18. Blue with red tracer, then set to position 3. Online it says set to position.2. For the jvc head unit
Still can't get it to program.
Hit - 20 c here last night. So she sits. Today.
I solder and shrink tube all of my connections. But thanks for the tip
__________________
