LED reverse/work light install - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 74 Old 12-20-2013, 05:37 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Thought I would share...
36 watt CREE LED 7" Bars mounted to tabs, welded to the hitch frame. They are wired to come on every time its in reverse or I can manually switch them on.
LED reverse/work light install-imageuploadedbyautoguide1387593336.913988.jpg
LED reverse/work light install-imageuploadedbyautoguide1387593364.808165.jpg
LED reverse/work light install-imageuploadedbyautoguide1387593406.628031.jpg
LED reverse/work light install-imageuploadedbyautoguide1387593421.708415.jpg
LED reverse/work light install-imageuploadedbyautoguide1387593456.008270.jpg
Sent from AutoGuide.com App
amdriven2liv, trophy_23 and Stiles like this.
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 74 Old 12-20-2013, 05:38 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
LED reverse/work light install-imageuploadedbyautoguide1387593497.663515.jpg
LED reverse/work light install-imageuploadedbyautoguide1387593530.583599.jpg
^Single post dual throw relay
amdriven2liv likes this.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #3 of 74 Old 12-20-2013, 07:40 PM
Beast2be350's Avatar
Looking good. Could use to straight up the wiring but other then that nice and function able
05 black xlt 6.0
03 turbo w/ wicked wheel
ARP head studs oem gasket
Egr delete kit
Blue spring
Bulletproof 48v FICM
6" rough country lift/ fuel kranks 20x11 -44 w/ 35s
Harley-Davidson head lights
K&N intake
4" straight pipe custom dual 6" tips
Pioneer 7" double din single 12" sub.
SCT live wire 5015 running Vivian's looney Wild tune.
Glowshift 4 pod. Egt, boost, trans, fuel pressure.
Beast2be350 is offline
post #4 of 74 Old 12-20-2013, 10:27 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Yea the electrical tape they sell at walmart apparently isnt worth 50cents a role so i didnt even bother wrapping it. Maybe if i get motivated enough i will tuck it in some wire loom lol
SpencerSr likes this.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 74 Old 12-21-2013, 02:30 PM
rr06psd's Avatar
Looks good. Those lights are bright. Can you post brand and part numbers for relay and leds. I have extra backup lights but there not led and only work on reverse. Thanks
2006 F-250 Lariat FX4 CCSB
BPD EGR Cooler
BPD Oil with cold Weather
Amsoil Bypass
Baldwin Coolant Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Silverline 4'' turbo back
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #6 of 74 Old 12-21-2013, 03:05 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
http://m.ebay.com/itm?itemId=281198564353
^link to the LED lights. The relay that you need is a single post dual throw automotive relay 30 amp is usually the norm for them. You can buy them online or at pretty much any auto store, i got mine from napa. One of the pictures is a horribly drawn out diagram of the wiring... Reverse light wire on the truck is black with pink tracer. The trailer AUX power is what I used to power them when I am in reverse since thats a 15 amp circuit and my trailer doesnt have reverse lights... That wire is the center pin on the rv plug, I believe its black with green tracer.
Ontario Trucker likes this.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
The Following User Says Thank You to ps_lane01 For This Useful Post:
rr06psd (12-21-2013)
post #7 of 74 Old 02-18-2014, 03:54 PM
MUDSLTOR's Avatar
Attachment 216162
Attachment 216170
Attachment 216178
Attachment 216186
Attachment 216194
I am considering this same set-up. You don't happen to recall the guage of wiring you used do you?
'05 6.0L PSD CC Purchased on 4/22/13
Need to really get a good look in the engine compartment to see what all has been done for sure.
4" Turbo back exhaust 6" Fab Tech Lift w/ dual steering Stabalizers 35" tires 92K miles
I promise to update as much as I can with my limited knowledge of the PSD and add some pics too.
MUDSLTOR is offline
post #8 of 74 Old 03-11-2014, 06:50 PM
PyroTekRob's Avatar
Quoted: 328 Post(s)
I was actually just buying parts to do this also. I was going to use 18W LED work spots. I wanted to wire up a 3 way switch, so I could have "ON" / "ON w/ Reverse" / "OFF"
2006 F250 Amarillo 4x4 CCLB - 210,xxx
SCT Livewire TS - Tunes from Vivian (Eco, Tow, Tow w/ JB, Looney)
DrawTite Flip Over Goose
Leveling Kit - Wildpeak AT3Ws 325/75R18
Sinister Diesel Coolant Filter
Garrett Powermax Turbo
DC Power Engineering 185amp Alt.
BPD Heavy Air Oil Cooler
BPD EGR
LED bulb upgrades.
Curt Class V - Air Lift Load Level 5k Ult - Wireless Compr
PyroTekRob is offline
post #9 of 74 Old 03-22-2014, 05:22 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Did u get this wired up? Interested to see how you did it? A two post switch or dual post dual throw relay?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #10 of 74 Old 03-22-2014, 05:33 AM
Ontario Trucker's Avatar
Well done, can never have too much lighting back there...
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
