PCM connector removal - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-20-2013, 01:37 PM Thread Starter
I have a 2005 6.0 Powerstroke F350 and I noticed that my intake air temperature #1 (IAT1) sensor was always reporting 4.97 volts--or about 58 deg F (P0113 DTC thrown). It looked like either the sensor had failed or the wiring had opened. I replaced the mass air flow sensor (MAF) in which IAT1 is housed. No difference. So I wanted to check the wiring--which comes from the PCM. However, I can't figure out how to remove the connectors on the PCM. There is a lever which you can pull that backs the connector out a bit, but I don't see how to complete the connector removal. What am I missing?
yankee10 is offline
post #2 of 4 Old 12-20-2013, 02:03 PM
ZMANN's Avatar
Quoted: 1350 Post(s)
u have the battery out ?
We Miss you Ronnie
ZMANN is online now
post #3 of 4 Old 12-20-2013, 02:05 PM
ZMANN's Avatar
make sure you flip the lever back all the way it helps eject the connector then just wiggle if need be ( the connector not yourself )
We Miss you Ronnie
ZMANN is online now
post #4 of 4 Old 12-21-2013, 07:38 AM Thread Starter
Thanks. The picture helps. I did take the battery out and moved the levers as far as I could. Don't remember if they got as far as what you show. I had wiggled like crazy but was afraid there was some other restraining device and didn't want to break it.
Is it more effective to wiggle side-to-side or up-and-down? Should I do this by hand or would some leverage help (or break) it?
yankee10 is offline
