Aftermarket radio install accessories advice - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 12-16-2013, 09:57 AM Thread Starter
dieseldan73's Avatar
Good afternoon everyone, I just picked up a Pioneer P4400BH off a friend, and need the install kit, wiring harness and steering wheel control module for my 2005 F-350 King Ranch. I normally do all my own research, but there are some many different kinds and brands its making my head spin. So I figured I'd ask you since many of you had installed aftermarket head units. I figured you could point me in the right direction. Thanks.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
post #2 of 14 Old 12-16-2013, 02:26 PM
ParkCity.PSD's Avatar
Looking for the same info...I know some others have done it. I'm thinking of going to best buy to see what they have for an install kit and harness. We'll see. I'm sure it's cheaper online, but I'm trying to install this soon.
06 F350 Lariat
Edge Insight CS
Blue Spring Update, EGR Delete, STC update, Stand Pipes and Dummy Plugs, Turbo feed and drain tube update, Sinister coolant filter, New stock oil cooler, Zerex ELC, RiffRaff Boots, Isspro Fuel PSI, DC Alternator, ARP Studs, Heads from Jared, OEM Head Gaskets, Yukon Dura-Grip Posi
Warren 155cc/stock injectors
SCT with tunes from Vivian
Western 8-1/2ft Pro Plow with UltraMount
Hansen Front Mount Snow Blower
ParkCity.PSD is offline
post #3 of 14 Old 12-16-2013, 06:04 PM Thread Starter
Just found out that it comes with a PAC SWI-RC. Crutchfield shows this as compatible with my truck. Now just need the mounting kit and wiring harness.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #4 of 14 Old 12-17-2013, 07:30 AM
I found the mounting kit and wiring harness on Amazon for really cheap...like $4 and $9 or something. I'm still going to look at BestBuy just because I'm in a bit of a hurry but if it's much more than that I think I'll have to wait...
06 F350 Lariat
Edge Insight CS
post #5 of 14 Old 12-23-2013, 06:17 AM
if you haven't looked already....
best buy wants $20 for the ford radio pigtail, and $20 for the plastic dash install kit, so $40 and you still need to find the PAC steering wheel control module (they sure didn't have them in stock at my local store, but i wasn't looking either since my truck is a strippie and doesn't have em)
i found the 2 peices i need for <$20 on amazon, so yea. I'd like to install mine tonight too, but im going to order online and wait it out to save $20
housew is offline
post #6 of 14 Old 12-23-2013, 08:17 AM Thread Starter
Thanks, I will probably get mine off amazon, I'm in no big hurry. Also I found out it comes with the steering wheel control I need.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #7 of 14 Old 12-24-2013, 09:30 AM
jlmotox's Avatar
Just need the wire harness and plastic double din dash mount, any brand
Get the PAC steering wheel module, it's the only brand I hear good things about.
Install is pretty easy and straight forward.
Here is my pioneer x930bt
Aftermarket radio install accessories advice-imageuploadedbyautoguide1387909620.350518.jpg
With the pioneer back up cam
Aftermarket radio install accessories advice-imageuploadedbyautoguide1387909681.084552.jpg
Aftermarket radio install accessories advice-imageuploadedbyautoguide1387909719.782778.jpg
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
post #8 of 14 Old 12-29-2013, 03:23 PM
Car Stereo Radio Kit Dash Installation Mounting Trim Bezel with Wiring Harness | eBay
I got this kit for my AppRadio. Super easy to use kit. Simply break off the tabs you dont need, wire the harness to your stereo harness and your good to go... Takes longer to take the dash off than it does to install it with this kit... I didn't opt for the steering wheel kit as I never used the volume controls anyway... I did not loose AC or any other steering wheel function. Look up MicroBypass to bypass the parking break wiring... Much easier and lets you use your video functions on the fly if your kiddos want to watch something. Just keep your eyes on the road! LOL
Hope this helps!
wildchild200 likes this.
TxOutlaw is offline
post #9 of 14 Old 01-16-2014, 06:39 PM
jlmotox, Now that you have had some time with it, how are you liking that setup so far? Looks like something I would put in my rig.
Thanks, Aintskeerd
Aintskeerd is offline
post #10 of 14 Old 01-16-2014, 10:08 PM
jlmotox's Avatar
Thanks, Aintskeerd
Still love it! No problems at all.
jlmotox is offline
The Following User Says Thank You to jlmotox For This Useful Post:
06Mike (01-20-2014)
