LED off road lights vs KC Dayliters - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-16-2013, 08:22 AM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
Hi,
Has anyone compared these LED lights to the original style KC off road lights. One is measured in lumens and one is measured in candlepower and these 2 measurements are totally different.
Many of these LED light bars have both spot and flood lights in a unit. They are more money than your normal off road lights but if they are brighter and last much longer it may be worth the added cost. They say these LED bulbs can last 50,000 hours.
Thanks!
2007 F-250 Lariat PSD 6.0 4x4 Crew Cab
FordPSD6.0 is offline
post #2 of 14 Old 12-23-2013, 04:45 AM
MikesF350ps's Avatar
Quoted: 5 Post(s)
Garage
I replaced the 4 KC lights with a 30" spot/flood Led bar what different, I got mine off ebay.
2007 F-350 4X4, 6.0L, Leveled
ARP Studs, OEM Gasket, EGR Delete, Oil Cooler
EGT, Volt, Water and Fuel Pressure Gauges
MBRP Exhaust w/Cat & Muffler Delete
AVH P 3200 BT with Back up Camera & XM Satellite
High Idle Mod, LEDís All Around ,Viair Air System for Air Horns, XDP Coolant filtration
08 Style Mirrors, Tailgate and Bumper, SCT Livewire TS Amerihood Functional Ram Air Hood with Heat Extractions Vents and S&B Cold Intake
2015 Keystone Montana 3791RD 5th Wheel
MikesF350ps is offline
post #3 of 14 Old 12-23-2013, 09:10 AM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
Mike can you put just the flood lights on or just the spot lights on? Did it come with a harness?
post #4 of 14 Old 12-23-2013, 09:26 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
Here are some charts for you.....LED all the way
And heres the real comparison
-Julian
4th 6.fo
TwinTurboStroker is offline
post #5 of 14 Old 12-23-2013, 01:27 PM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
If you get a light bar with 2 different types of lighting in it, can you turn either one on by itself or must the whole light bar be on?
post #6 of 14 Old 12-23-2013, 01:29 PM
Raul@Stealth Automotive's Avatar
its all on at the same time
Raul@Stealth Automotive is offline
post #7 of 14 Old 12-23-2013, 01:32 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive also read that their is not much of a diffrence in the cheap led's and the fancy exspensive one's (besides the cost). True or no?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 14 Old 12-23-2013, 01:40 PM
Well... i a lil bit.. .its not just LED's you need to worry about.. they may all have the same LED's but what about the actual bar itself? or the wiring? .. im a big believer that you get what you pay for... im not saying go and buy a Rigid light because i feel they are overpriced.. .
if it were me i would buy bulldog lighting because not only is the price cheaper than Rigids but they are actually made in the USA...
post #9 of 14 Old 12-23-2013, 07:57 PM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
Wow. Bulldog 40" is $1200!
post #10 of 14 Old 12-23-2013, 07:59 PM Thread Starter
FordPSD6.0's Avatar
Quoted: 3 Post(s)
TwinTurbo thanks for the charts. 17,000 posts! Are you kiddin me!
