Recommendations: Looking for Monitor/Tuning solution - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-10-2013, 11:33 AM Thread Starter
Hi all,
Looks like I just blew out my EGR and Oil coolers so I am installing the BPD kit with the cold weather option (Utah). While I'm at it I want a tuning/monitoring solution that will allow me to route the display to an in dash DVD player. What do you recommend?
Wouldn't mind recommendations for the indash player either. I also want to install a backup cam.
Early 2004 F-350 6.0L Powerstroke 4X4 Dually.
112,000 miles
CNG kit.
Soon:
BPD EGR cooler
BPD remote oil cooler.
BPD coolant filter.
Dave
Diesel Noob
davemcp is offline
post #2 of 3 Old 12-23-2013, 09:14 AM
1st, I would recommend a cooler delete, its cheaper, you will get a bit more performance, and it can pass emissions Depending on how they do it. It will pass with stock tune as long as its an opacity test (like here in CO).
2nd. Tuning, go with SCT, the custom tunes are insane compared to stock. The new livewire TS will be a monitor and tuner in one, not sure how great the monitor functionality is but will tune like any other SCT. Non-livewire models will monitor most things but they are ugly to have in the cab.
3rd. There ia an android app called Torque or something similar that connects via a OBDII bluetooth plug, so if there is an in dash android based device thats an option. Otherwise there are a few forums ive seen that I cannot find that address this specifically. I think a user named Tuscany described his setup. You can search for his page and see previous posts, or maybe pm him.
Hope this helps
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #3 of 3 Old 12-23-2013, 09:40 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
A monitor is where I would start, I do not know if you have checked out the stickies but there is a lot of good info there. Check this out Write Up: Monitoring the 6.0L PSD.
A monitor really is a personal preference, I have a dash boss and I love it I can monitor egt and fuel pressure but I hear edge cts is good as well. Now as far as a programmer sct is going to be best, I have a live wire with custom tunes from Vivian but there are many different tuners out there. Some other good options as far as performance are ficm tune from php or a billet wheel on your turbo. It really depends on what your goals are.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
