Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 09-02-2008, 10:16 AM
slammedSI slammedSI is offline
A cow says , Moooo
Vacuum Pump?
Hey, been trying to get my ac to work right again. It only blows through the defrost vents. I found a leak yeasterday and it fixed the problem. I went to my ranch and had to used 4wd and it reverted back to the defrost vents, and now i cant get it to go back to the normal vents. no leakes that i can find. tryed to take a multi meter to check for power to the pump but didnt get the littlest bit. not sure if it only runs during a sertin time or not. What do yall recomend? Sure is hot with no AC
Old 09-02-2008, 10:41 AM
03f250stroke 03f250stroke is offline
haha mine does the same thing, i only use my 4wd at the track..and A/C. i never use that. but my truck has the 4wd switch on the fly but i still have to lock my hubs. my other truck had the manual on the floor so im use to it. either way i would love to know how you fixed it or how i could fix my also
Old 09-02-2008, 11:55 AM
A cow says , Moooo
Just a bump. ive gotta get this fixed.
Old 09-02-2008, 12:33 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
are you hubs auto locking? if not sounds like a leaky hub seal..
Old 09-02-2008, 03:11 PM
A cow says , Moooo
Well i think i found the problem. I pulled the vacuum pump off. and hooked a 12v to it. and nothing. didnt make a peep. So i pulled the dust cover off it and it smells like its been cooked in the oven at 450 for 3hrs. so im pretty sure its toast. anyone have any ideas on a universal one i can get? ford wants 170 bucks for this LITTLE pump.
Old 09-02-2008, 05:13 PM
tech10002 tech10002 is offline
I don't think you're gonna find a universal replacement. These things are basically only used on diesels. This is the cheapest I've ever found them: eBay Motors: 04-07 FORD SUPER DUTY 6.0 ELECTRIC VACUUM PUMP (item 220235889390 end time Sep-13-08 10:23:12 PDT)
Old 09-02-2008, 05:21 PM
Here's another place I found a little cheaper. Ford Superduty ELECTRIC Vacuum Pump
The part number is F6TZ-2A451-AA in case you want to do some more looking.
Old 09-03-2008, 09:37 AM
A cow says , Moooo
Thanks for the help bud.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
