Trailer Connector Issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-10-2013, 04:14 AM Thread Starter
tinygiant's Avatar
All,
On the wifey's X, I'm currently unable to get any power to the trailer running lights, brake lights, turn signals (both), constant 12v. I do have power to the reverse lights. There are no blown fuses anywhere in the fuse box and all relays have been tested and are functioning correctly. In the process, I did find a blown fuse for the electronic climate control which, oddly enough, was working intermittently even with a blown fuse.
Any ideas on where else I should be looking to figure out why I have no power to most of the trailer connector?
..ed..
___|0o0|___
'04 Excursion PSD (Hers)
'03 F-350 PSD (His)
'05 BMW 325i (Her Daily Driver)
'08 Harley Davidson Fat Bob (His Daily Driver)
'79 Fairchild Republic A-10C
tinygiant is offline
post #2 of 6 Old 12-10-2013, 10:38 AM
are you checking the pins on the plug,or looking at the lights on the trailer itself?,if you have power at the plug,it sounds like a ground problem.when trailers sit a lot,they tend to corrode bad in the electrical areas.pull a couple of bulbs and see it they have any power too.Not much help,but something to think about.
Dark Satin 05 is offline
post #3 of 6 Old 12-10-2013, 10:56 AM Thread Starter
tinygiant's Avatar
I'm checking the pins. All lights on the trailer work fine when hooked up to my '03 F-350. Only backup lights from the X. Still can't track down the source as it appears all wiring is intact. This occurred while I was sitting at the horse barn loading up horses. Truck was idling in Park and all lights just went out. All lighting on the X still works fine.
I also don't suspect the trailer as I just rewired it with all water-proof LED lights, have re-checked all connections to ground and ensured there are no exposed wires. All wires in the trailer are crimped, soldered and heat shrunk. The ones I couldn't solder have the heat shrink butt connectors (sts) on them.
..ed..
___|0o0|___
'03 F-350 PSD (His)
post #4 of 6 Old 12-12-2013, 04:53 AM
check the back of the plug on the truck,i believe it plugs into a harness.it might have come loose or be corroded?see it it will come apart and see if any power there.
post #5 of 6 Old 12-14-2013, 04:00 PM Thread Starter
tinygiant's Avatar
The harness is pretty tight, but I'll take it off and check at the harness to see if the plug is the issue.
Thanks,
..ed..
___|0o0|___
'03 F-350 PSD (His)
post #6 of 6 Old 01-27-2014, 03:02 AM Thread Starter
tinygiant's Avatar
Finally got power back there. Now everything works except the brake lights (blinkers works fine). Turns out that Dark Satin was correct, the plug had worked itself loose for some reason. Pushed it back on and everything worked great (except the brakes)! Also, the brake controller recognized a connected trailer, but wouldn't provide any power to the brakes. I'm assuming the brake light issue and brake controller issue are related, but haven't sat down to figure this one out yet.
..ed..
___|0o0|___
'03 F-350 PSD (His)
