05 heat blower not working all the time? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-05-2013, 05:40 PM Thread Starter
Have a 05 SD,problem is sometimes when I start the truck,the heater controls will not work,no fan speed or cant change the vents.not always but the odd time,it is needed now that the cold is here,after I drive around for a couple of minutes it will start working on its own?no change if I play with the knobs either,not a big deal but it is annoying. Also is there a light in the heater control that can be replaced?,mine is in darkness now,my truck does not have the climate control type of controls. Harvey
Dark Satin 05 is offline
post #2 of 8 Old 12-05-2013, 09:19 PM
do you have the fancy digital controls
grn0660 is offline
post #3 of 8 Old 12-06-2013, 03:21 AM Thread Starter
No,it just has the basic one,it almost seems like it is vacuum related?
post #4 of 8 Old 12-09-2013, 07:31 PM
ok sounds like you need a new blower fan resistor youtube has videos on how to replace them really really simple only takes about 10 minutes to do. oreily's has oem motorcraft resistors for like 15 bucks.
grn0660 is offline
post #5 of 8 Old 12-14-2013, 06:56 PM
pleonard's Avatar
Subscribed ... same problem same year . Like to hear your outcome after that resistor replacement
pleonard is offline
post #6 of 8 Old 12-16-2013, 06:02 AM
pleonard's Avatar
Just bought a blower fan resistor for my truck... he turned on and was blowing good on all speeds. Shut the truck off went out 2 hours later to leave and again my fan isn't blowing . Any ideas ?
pleonard is offline
post #7 of 8 Old 12-16-2013, 06:18 AM Thread Starter
in one of my earlier posts I mentioned it seemed to be vacuum related,has anyone had any experience with the vacuum pump under the hood,it is over by the heater box?,somehow I think it is something to do with that. Harvey
post #8 of 8 Old 12-19-2013, 06:46 AM
pleonard's Avatar
I replaced the resistor ... still didn't work . Sacked the blower motor with a hammer and it fired up . Replaced motor 58$ and its all fixed
pleonard is offline
