Edge Insight fuel pressure warning/alarm - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-04-2013, 06:04 PM Thread Starter
Hey folks,
So, its not that big of a deal but Id like to see what others have done to eliminate this annoyance. I have my alarm set for 45psi or less on the fuel pressure. So everytime I shut the truck down and the fuel pressure drops, the alarm beeps untill the unit shuts off wich is an additional 10-20 seconds after the ignition is turned off. The alarm beeps this entire time as the fuel pressure drops below 45psi. I dont want to kill the alarm or shut the "beep" off as Id like to hear it if it were to drop under load/boost....Just curious to hear what others have done in this senario.
'05 DRW CC
ARP studs,B/O HG's,RCD EGR del,SCT(Innovative),4" turbo back,AFE Stg1,Edge Insight,CT 5R110,Dieselsite trans filter,Dfuser coolant filter,CCV mod,Sprintech lowering shackles,Recon smoked everything+Tailgate lightbar,LED conversion,DeVries emblems,billet grille,All Ford avail updates after 2005.
mygt8a4re is offline
