Radio install questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-04-2013, 11:20 AM Thread Starter
Mike UK's Avatar
I'm installing a Pioneer double din head unit and I need to replace the ford plug as I can't find an adaptor. I need to know what color wires do what and why there are 14 of them?
Any help wil be very much appriciated
Thanks
Michael
Mike UK is offline
post #2 of 9 Old 12-04-2013, 02:04 PM
Nifty2Fifty's Avatar
Best buy usually sells them. I got my harness and bracket for about 50 bucks when I installed mine.
But if you still cant find the harness, how about a little information on your truck? Year and model would help us point you in the correct direction.
Example, my truck is an 06 F250 XLT
2006 Ford F-250 6.0L
XDP Coolant Filter System - Bluespring Upgrade
Bushwhacker Pocket Style fender flares, Herculiner down the rockers
MBRP 4" Turbo back Exhaust
Nifty2Fifty is offline
post #3 of 9 Old 12-04-2013, 02:10 PM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
save the headache and order the harness for the radio and the steering controls
GD
Heavy_GD is offline
post #4 of 9 Old 12-04-2013, 02:57 PM Thread Starter
Mike UK's Avatar
Thanks for your replies
The problem I am having is finding a harness that's adapts a US iso to a European one as I live in England. As far as I can tell they are different.
The truck is an 04 F-350 lariat king ranch.
Mike UK is offline
post #5 of 9 Old 12-04-2013, 03:17 PM
Heavy_GD's Avatar
ahh I thought you went to UofK... now that screen name makes sense.
GD
Heavy_GD is offline
post #6 of 9 Old 12-04-2013, 03:23 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
Have u tried crutchfield? For speakers you can always take a 9v battery (if available there) and scratch positive and negative and listen for the crackle of the speaker. Red should be constant blue should be "remote " and yellow/orange should be illumination. At least iirc
sent from everywhere...
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #7 of 9 Old 12-05-2013, 03:50 AM Thread Starter
Mike UK's Avatar
That's great help thanks. I'll be chopping and changing the iso on Sunday if I can't find an alternative by then.
Mike UK is offline
post #8 of 9 Old 12-05-2013, 08:41 AM
Heres the basics for ya:
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Pink
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
to be honest, and hope this doesnt come across wrong, but, all I did was do a google search for "2004 f350 radio wiring diagram" and a ton of pics and links showed up. This was the easiest to copy and paste....
mygt8a4re is offline
The Following User Says Thank You to mygt8a4re For This Useful Post:
Mike UK (12-08-2013)
post #9 of 9 Old 12-05-2013, 08:43 AM
Heres a pic that may help as well:
http://fordf150.net/photos/data/4226...adio_1to12.JPG
'05 DRW CC
ARP studs,B/O HG's,RCD EGR del,SCT(Innovative),4" turbo back,AFE Stg1,Edge Insight,CT 5R110,Dieselsite trans filter,Dfuser coolant filter,CCV mod,Sprintech lowering shackles,Recon smoked everything+Tailgate lightbar,LED conversion,DeVries emblems,billet grille,All Ford avail updates after 2005.
