Torque Pro Accuracy - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-24-2013, 04:12 PM Thread Starter
Zak77's Avatar
Quoted: 2 Post(s)
Torque Pro Accuracy
Has anyone experienced any issues with Torque Pro and accuracy? On my 03 X, 6.0L it seems to be a little odd as once warmed up my trans and coolant stay at around same temp, usually 179-181 and literally always between a half of a degree from each other. My oil temp though is 30-50 degrees higher. Oil seems to run in the 220-225 range on the highway. No matter what the outside temp is, the oil is 210-225 and coolant/trans temp always seem to be in the range above.
FIMC is 48 and voltage system usually in the higher 13's. Cant remember any of the other numbers.
Do these numbers strike anyone as odd? I ordered an oil cooler and EGR delete and they will be installed soon, but I'm just mystified as to why the trans/coolant seem to always be at the same temp.
Zak77 is offline
post #2 of 9 Old 11-25-2013, 01:43 PM
seanol's Avatar
I have had good success with my Torque app. I have the BDP oil cooler and see a difference between all the temps. You may be seeing the temps close due to the coolant cooling the oil as well, keeping temps within a certain range.
I do have different temps between trans and coolant. If not, I would be looking for a trans by now! I see between 160 to 180 degrees on a 25 mile highway commute.
Oil temp gets to about 180 right now (50's in the morning) and coolant is around 200 degrees.
You may want to see if there is a different PID for trans temp, that could be an issue.
Sean
seanol is offline
post #3 of 9 Old 11-25-2013, 02:57 PM
johnnybgood's Avatar
Quoted: 82 Post(s)
I feel the torque app is accurate on my 05 X. For the trans temp, like seanol said, it's probably a different PID you have to select. For mine, there were two I could select from. One matched the ect exactly, the other was accurate to the trans temp. Try looking through them all with the truck running, you'll see what's available.
I don't have all that much experience in a 6.0 or diesels yet, but your oil temp seems way to high with way to much of a spread imo. Either way, looks like you got it covered with the coolers tho. G'luck.
johnnybgood is offline
post #4 of 9 Old 11-25-2013, 04:47 PM
for me it is very accurate and super responsive I use it all the time to monitor everything
grn0660 is offline
post #5 of 9 Old 12-01-2013, 07:16 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
There is a PID that gets coolant temperature from the TCM. There are several PIDS in the app so you might have to bring up a blank dashboard and put all of them on there to see which one is correct.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #6 of 9 Old 07-05-2015, 08:27 AM
Quoted: 13 Post(s)
I think I am going to try Torque Pro for my 04 6.0, I would like to know what adapter you recommend. Bluetooth, wireless or wired? I see them anywhere from like $6 to $100.
Sdwyer41 is offline
post #7 of 9 Old 07-05-2015, 08:37 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
Bluetooth is great and there are a lot of options you can go expensive from Scantool.net or from Amazon like the Vgate or BAFX; I would not do the 6 buck adapters though, you get what you pay for. Check this link: Bluetooth Adapters - Torque OBD2 Wiki
Shawn
Qholic is offline
The Following User Says Thank You to Qholic For This Useful Post:
Sdwyer41 (07-05-2015)
post #8 of 9 Old 07-05-2015, 08:45 AM
Quoted: 13 Post(s)
So all the Scantool adapters work with Torque Pro? There are some decently priced Scantool adapters on amazon. I will probably go with that.
Sdwyer41 is offline
post #9 of 9 Old 07-05-2015, 08:49 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
Yes, I will probably come off my wallet and get one because I like the idea of their sleep mode and faster read speeds.
Edit: I believe G8Ford here on the org uses one you might want to PM him and see what he has to say about it.
Shawn
Qholic is offline
