Backup Sensor and Reverse lights out - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-22-2013, 03:33 PM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Looked up 100 threads but all let to a busted fuse or bad sensor. Do the reverse lights and backup sensors run on the same circuit? I had high clearance bumpers built and they re-used the backup sensors in the bumper but, since i got the truck back, I cannot get the backup sensors or reverse lights to work. My backup camera switch power is tied off my reverse lights so it's extremely inconvenient.
Fuses are all good and the back up sensor light doesn't come on when i put it in reverse so i do not think i have a bad sensor, i feel like i am missing something obvious here. The license plate lights were not working either, by some stroke of bad luck, they both burned out so I replaced them thinking they were wired in sequence with the backup lights and sensors but that fix the issue. Any ideas??
OCVeloMan is offline
post #2 of 4 Old 11-23-2013, 07:42 PM
asian195's Avatar
Quoted: 2 Post(s)
I would check for a loose ground wire. Or if they grounded it to a painted surface.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #3 of 4 Old 11-24-2013, 09:03 AM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Kinda my thought as well. Was just hoping there was something simple I was missing like a hidden in line fuse.
post #4 of 4 Old 11-25-2013, 02:15 PM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Well, grounds are all good so it looks like I need to have it looked at as I've exhausted the extent of my low-voltage capability.
