fuel gauge issues - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-22-2013, 06:22 AM Thread Starter
RedneckYankee's Avatar
fuel gauge issues
Need some help guys. This is what is going on. 2005 Excursion with 6.0 the fuel gauge reads normal then out of the blue it drops to Empty and the low fuel light comes on. The miles to empty gauge still reads normal. You can cycle the ignition and nothing changes. Then out of the blue the fuel gauge comes back to normal. Is this a grounding issue or is the fuel sending unit failing. No codes thrown on SCT tuner need to check with A scanner to see if it shows anything. Unfortunately I just had knee surgery and don't really need to be contorting my knee to much if I don't need to. Would this be an electrical problem with instrument cluster or the overhead Counsel? Thanks for any help.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #2 of 7 Old 11-23-2013, 06:46 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
I'm in to see a reply. My dads 03 has had the same problem for several years. He just kind of puts up with it.
Buddy of ours is a Ford master tech and suggested just replacing the whole sending unit. But at $400 and dropping the tank or lifting the bed, he wasn't to thrilled about that.
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
post #3 of 7 Old 12-30-2013, 04:02 AM
Therabbittree's Avatar
My '05 Excursion just lost the fuel gauge sender too. I had dropped the tank for a sump install etc. Mine is not working at all truck has 200k on chassis. My Ford Tech friend said the senders normally go bad especially had High miles or if you pull the tank and clean the sender off.. I will be ordering one soon myself. my miles to empty does not work and my scan guage II mpg and tank features do not work. FYI the Price for the Fuel Guage Sender from Autonation ( used to be Trousley) is $262 with $400 something list price.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #4 of 7 Old 12-30-2013, 06:35 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
U can check with a scanner, pull up the fuel level sensor pid. If you have a full tank and the pid shows something similar and your instrument cluster is at empty then your gauge is bad (not so common). If you have a good scanner you can read instrument cluster and tcm DTCs- it will throw a circuit high/low code and you will then know its either your sender or wiring issue. If your pid is zero, low, extremely high, you could have a wiring issue- try moving the 4way connector under the truck below the firewall. OR, your fuel level sender is broken- most common... This is how my truck has been since i bought it. After a few times running out of fuel you live with it, but i hope to fix it this winter.
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 7 Old 12-30-2013, 06:40 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Mine does something similar. If I let the truck idle for a minute or two gauge will drop to empty. Go drive around or restart the truck and 9/10 times it will read normal.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #6 of 7 Old 01-01-2014, 01:35 PM
Quoted: 3 Post(s)
Mine hasnt worked since the day i got it, i put a new sender in, didnt fix anything, dont waste your money on that, i thought it might be in the cluster since i fixed the sender, so i ran a secondary gauge, it read the same thing and now both gauges read empty
mySIXOisSick is offline
post #7 of 7 Old 01-02-2014, 04:55 AM
Mine worked perfect till I dropped my tank for sump install. It should be fine with new sender. Either way I will check the wiring also. My Ford tech friend mentioned that ford recommended a special fuel supplement to help the sender work again?..I think it was textron? or pextron?.. He said it only worked 1/2 the time. His best solution is a new sender.
Thanks,
Deo
