Dead battery after alternator replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-20-2013, 03:47 PM Thread Starter
I have a 2005 F-250 XLT 4x4 and had some issues with slow cranking at start up. I had the batteries tested once with no problems found. After the first test I had a dead battery and had the charging system tested again with no problem found. Third time it turns out the alternator was not charging under load and the alternator was replaced. This is the second OEM alternator replaced and the batteries were replaced when the first alternator went in.
Less than 24 hours after replacing the alternator I have dead batteries again. There are no obvious lights on, to include dim lights in the cab or headlights after dark and the battery connections appear to be good.
Any thoughts on where I should start tracking this down or should I just pull the batteries and have them tested out of the vehicle?
sapper336 is offline
post #2 of 3 Old 11-21-2013, 05:53 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 466 Post(s)
Garage
Once you get it started up again check output voltage and make sure it's charging properly.
Most rebuilt alts are junk. 140 amp minimum is dust these trucks really need. Be carefully about letting batteries get too weak, that will damage ficm and you will need to fix that too.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 3 Old 11-23-2013, 12:33 AM
john galt's Avatar
Quoted: 1230 Post(s)
i had a similar problem and found a bad cable so the charge wasn't constant and strong...if that makes sense. best i got at 1:00 am ...i REALLY gotta get some sleep
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
