Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 11-08-2006, 06:44 AM
PowerItUp PowerItUp is offline
12V Source When Key is off
Does anybody know what wire I can use and where it is. Heres what I want to do. I have a Sirius sportster that I have hard wired now to a key on source. But if you turn the truck off, power goes off. I want to tap into the source that continues for like 20 min. after the key is off. You know the one that allows the radio to play after removing the key. Any help is appreciated.
Old 11-08-2006, 07:10 AM
Logan Logan is offline
The Fat Mod
You could go into your fuse panel with a light tester and see which one stayed on for a bit after you kill the switch.
Old 11-08-2006, 07:19 AM
Thanks, I'll try that brrs3633. Was trying to save some time and hoping someone knew.
Old 11-08-2006, 08:44 AM
The Fat Mod
Yeah sorry, I am not sure on the 6.0s But, maybe someone will be along shortly to tell ya.
On the other hand, I would not think it would take that long to check with a tester. Just pull the panel and turn the truck on, and then shut it off and go down the row testing on top. You should be able to find a good one pretty fast.
Old 11-08-2006, 08:02 PM
lilredpowerstroke lilredpowerstroke is offline
How about splicing into the power wire for radio???
Old 11-09-2006, 08:30 AM
You're too funny ! So you know which one it is right? I'll find it, just haven't had time. I'll post back when I do.
Old 11-10-2006, 04:58 PM
Keith T Keith T is offline
Clint;
This should help. If you want the entire page send me a PM with your email address.
Keith
Old 11-11-2006, 05:30 PM
Originally Posted by Keith T View Post
Clint;
Keith
That'll do it. Thanks.
Old 11-12-2006, 07:00 AM
Glad I could help. Keith
