04 instrument cluster swap - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-13-2013, 05:42 AM Thread Starter
jake_duet's Avatar
Has anyone swapped the 04 cluster to the 05-07 cluster? If so, is it hard to do, or is it just a plug and play type deal?
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 3 Old 02-01-2014, 07:04 PM
Did you figure it out
2004 F350 6.0 Crew Cab/Long Bed
--NEWEST PROJECT--
mkeevo is offline
post #3 of 3 Old 02-01-2014, 08:05 PM Thread Starter
jake_duet's Avatar
It is not possible to do due to different wiring harness and different gauges/gauge layout.
S&B Intake
EGR Delete Kit
blue spring upgrade
updated oil cooler
Mf. Date July, 2003
"Keep on Strokinn"
Tags
cluster , gauges , instrument , old to new , swap
