NO HEAT - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-12-2013, 05:27 AM Thread Starter
NO HEAT
I have a 2004 f250 with manual controls and I have no heat. Blower motor will not come on unless I jump pos and neg terminals, even then I have no heat. Blower motor relay is good(switched it out with another one to test). I have no way to get this truck into a shop for diagnosis because of my work schedule. I'm in northern colorado and I need the heat to work.
hambone_01_7 is offline
post #2 of 5 Old 11-12-2013, 05:43 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Well you know you have power to the motor. Id check the ground side. If both are good then its gotta turn or the motor is junk.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 11-12-2013, 06:25 AM Thread Starter
The motor does turn and the speed knob will control it when I have it jumped, when the relay is in...nothing. Would it be the resistor, the whole panel where the speed, temp, and vent knobs are? I'm at a loss...my temp ranges from 185-195 and both inlet and outlet hoses from the heater core are hot so that should rule out the little valve that is in the coolant line
post #4 of 5 Old 11-13-2013, 12:20 PM Thread Starter
Nobody has any ideas?
post #5 of 5 Old 11-13-2013, 04:06 PM
I don't have a clue but if you move this to general discussion maybe more people will see it. I know it's a electrical issue but I don't think this section gets a lot of traffic
dominic350 is offline
