Interior electric going in and out - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-05-2013, 07:07 PM Thread Starter
Hello people.... My gauge needles, stereo and power windows go out with a clicking sound. Then I can either hit the dash a few times or it will come back on by its self. I have know idea where to begin looking. Please help thanks
FAAST is offline
post #2 of 6 Old 11-05-2013, 07:57 PM
PowerStrokedRedneck's Avatar
We had a similar issue at work with an '03 F550 7.3L. The dome light would flicker and had what sounded like a relay clicking hard behind the gauges. Turned out the gauge cluster failed and had to be replaced.
PowerStrokedRedneck is offline
post #3 of 6 Old 11-19-2013, 10:39 AM
Pistolgrip426's Avatar
ya,i've had a few 03-05's f550's do that,solder joints in the cluster board,got one doin' exact thing now,,
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #4 of 6 Old 02-12-2014, 06:31 PM
Serving On My Terms...
Would the bad solder joints make the tach drop out intermittently? And also have the climate control back lighting go out intermittently as well?
rhode8pe is offline
post #5 of 6 Old 02-15-2014, 04:38 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
I would check it out the grounds that are screwed to the metal framework of the dash. There are lots of them behind the trim for the instrument panel. I would also take a look at all the connections at the battery terminals as well as the fuse able link.
Just rule out everything else before you condem the instrument panel itself.
Good Luck with it.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #6 of 6 Old 02-15-2014, 06:33 PM
Thank you mhatlen, but its only happened once in the month I have been driving it, I will clean the terminal posts, they did look pretty crappy...and keep an eye out for any other glitches that pop up!
2007 F350 Super Duty....Blue Spring, FICM by Ed @ FICMrepair.com with Atlas 40 by PHP, Zerex Cat 1 ELC Coolant...
rhode8pe is offline
