trailer brakes - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-30-2013, 08:47 PM Thread Starter
STROKEDIS's Avatar
trailer brakes
ive been fighting a issue , my electric trailer brakes are not functioning on my truck ,hooked up to buddies chev and his new chev they work fine!!! sent to ford they checked all power at plug says all good changed fuses for trailer brakes and still no workiie !!! my other thought was could my seven pin and buddies chev seven pin have one terminal different there for not activating my brakes !!PLEASE HELP STOKEDIS
05 sd ,banks six gun tuner ,arp head studs ,bullet proof diesel egr cooler,upgraded fuel pump,upgraded fuel regulator banks air filter , turbo back 4 inch exhaust, 8 " lift 37's with 4.56 gears
STROKEDIS is offline
post #2 of 15 Old 10-30-2013, 11:19 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Ford, Chevy and Dodge all wire the trailer connectors the same. Maybe the problem is the trailers wiring. Make sure the harness going into the truck doesn't have a bad connection. If that don't work, check your trucks trailer plug yourself.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 15 Old 10-31-2013, 12:30 AM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
could be a small short that is just hard to find...
did you verify the fuses yourself after dealer? I had a small fuse blown driving me nutz for a few days...
you could go old school and get a hot light tester and volt meter too?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #4 of 15 Old 10-31-2013, 12:33 AM
WD40's Avatar
Quoted: 35 Post(s)
If they are working good on your buddy's Chevy and not on your truck then I think
it would be your plug in or your brake controller. Start with a test light and your plug.
Test all the wires, left turn, right turn, brake light, then running lights. If they are all
good then I think it would be a bad brake controller. If you can't do this work then
take your truck to a RV or trailer shop. Good Luck.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 15 Old 10-31-2013, 09:05 AM Thread Starter
STROKEDIS's Avatar
Thanks guys , no I didn't check fuses after ford did but a friend at ford worked on it and said he tested it , the brake controller was my first thought and its new now ....driving me nuts .trailer harness is good if it works on chev...
post #6 of 15 Old 10-31-2013, 01:09 PM
WD40's Avatar
Quoted: 35 Post(s)
Do you have a Ford brake controller or a aftermarket? You say it's new, so it
could be hooked up wrong or it may be bad from the maker. Sounds like
you got some more checking to do. We are talking about your 05 Ford?
Doug
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
post #7 of 15 Old 10-31-2013, 01:52 PM Thread Starter
STROKEDIS's Avatar
Wd40 it is a new ford controller,it was the first thing I changed then took to ford .
post #8 of 15 Old 10-31-2013, 02:06 PM
Quoted: 8 Post(s)
It's possible the trailer wiring has a short and when the Chevy hooked up to it the short went away.... Obivoiusly if you have power coming out the back of your trucks trailer plug then it's not the trucks issue.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 15 Old 10-31-2013, 02:34 PM Thread Starter
STROKEDIS's Avatar
Rollin, brake lights running lites turn signals all work fine in my truck ,hooked to friends truck the electric brakes will actuate ,hooked to mine they don't..... New controller ,brake pressure valve , fuses . This is the baffling part ...
post #10 of 15 Old 10-31-2013, 02:53 PM
Quoted: 8 Post(s)
Did you test the prong coming out of your trucks plug for the brakes themselves? I know you already tested the lights... But did you test the trailer brake prong?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
