Power point wiring diagram 2005 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-30-2013, 08:45 AM Thread Starter
Kmay's Avatar
Does anyone have a wiring schematic for this area? I am trying to put a switch panel where the PowerPoint is located and noticed there is an extra pigtail attached that I think goes to the passenger airbag on off switch. I need a switched power source and wondering if one is in that pigtail. The switch will be a lit on/off switch running to a relay for my air compressor.
Thanks for any tips.
Kyle
2005 F250 6.0l
ARP Studs - 6.4 Banjos - Blue Spring
EGR Delete - 4in Magnaflow Turbo Back
Sinister Coolant Filter - Fumotos - SG2
Zerex Cat EC1 ELC - High Idle - SCT w/SRL +
Atlas 40 - Isspro EV2's
Kmay is offline
post #2 of 2 Old 11-27-2013, 08:56 AM
Quoted: 3 Post(s)
That indeed sounds like the PAD Switch connector.
Should be 6 pins.
1 Not Used
2 Not Used
3 YE/LG PAD Switch, Indicator, Control
4 OG/YE Voltage supplied in Run
5 BK/OG Ground
6 WH/LB PAD Switch Signal
Lee
ve7fet is offline
