Kenwood Amp Install - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-30-2013, 04:43 AM Thread Starter
Kenwood Amp Install
Ok, so I've tried to search and I'm coming up empty.
I recently installed (4) Infinity Kappa 6.82.11cf speakers, (1) 10" Pioneer shallow mount sub all powered off a Kenwood XR900-5 amp.
The amp has the following adjustability:
Input sensitivity for channels A, B, and sub (5=min, .2= max)
Bass boost (0-8 in dB)
Low Pass Frequency for sub(50-200 Hz)
High Pass Frequency for CH A, B. (50-200 Hz)
My *main* question is what is the pre-out voltage on the factory 2006 6 cd changer to setup the input sensitivity.
My next questions would be advice on the filter frequencies. I will addjust the bass boost depending on how everything sounds once the others are tuned.
Thanks!
agpatrick12 is offline
post #2 of 4 Old 11-04-2013, 05:45 PM
elchaseo's Avatar
Quoted: 8 Post(s)
Thanks!
If I'm reading this right you are wanting to use the factory radio with the amp. There are no pre outs on the factory unit. You will need a line output converter to tap into a set of speakers. This will give you an unamplified RCA signal the amplifier can now use.
When ever I did the frequencies on the amp I always stared low pass around 120hz then moved as I felt necessary and left bass boost all the way down. Hope that helped maybe
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #3 of 4 Old 11-15-2013, 04:18 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
You need to go with a better stereo with low outputs.
You are not going to get the sound you deserve for the amp and speakers.
I know a few things about car stereo, if you look at my profile there are some pics of my all active 12 channel system.
Stereos aren't that expensive depending on how far you want to go
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 4 Old 11-15-2013, 05:10 PM
BrodieBiking's Avatar
Get a new deck, it'll save you some time.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
