Edge CTS reading 0 EBP - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-29-2013, 06:17 PM Thread Starter
6 L chevy eater's Avatar
Hey, wondering if you guys have run into same problem ? Edge CTS wasn't readin EBP at all so I replaced EBP sensor and cleaned the tube , re installed and now it's reading 0psi all the time. Any idea what could be the problem?
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #2 of 3 Old 10-29-2013, 06:33 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Its most likely a problem with the programmer. My spartan has blanks on things like engine coolant temp and torqueslip. It could be a sensor or something but its probably just the edge or your pcm
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #3 of 3 Old 11-09-2013, 06:00 AM
agreed^ mine reads 0 as well(ebp)
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
