CIG lighter--- Not Working - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-24-2013, 06:37 AM Thread Starter
My cig lighter wont work in the truck. I've replaced the fuse around 4 times and it has never worked. anybody got any suggestions on whats wrong with it? Anyone had any similar problems?
thanks
drobertson928 is offline
post #2 of 5 Old 10-24-2013, 05:39 PM
thanks
Yeah mine isn't working either. It worked fine up until a few months ago. Fuses are good and everything else on the dash works including the aux power spot. I only ever used it to plug my phone charger in so now I use the aux when I need to charge. Maybe one day I'll quit being lazy and actually try to figure out what's wrong with it.
CompIgnition is offline
post #3 of 5 Old 10-24-2013, 08:16 PM
DVCF450's Avatar
Cigar/Cig lighters are composed of a heating element, basically a wire wound resistor. If (when) it breaks, due to heat and age, there is an 'open' in the circuit, and no current will flow. No Heat. Also, unless it shorts to ground, no blown fuse. I have checked with a known good unit, and if it heats up, traced my way back to the fault in the harness. Good Luck!
2005 F-450 4WD DRW, 2x Deka 665MFs, 55w 6k headlights, BPD EGR cooler,BPD 100mm water pump,BPD all aluminum radiator,DC Power 190 amp Alternator,Utility box,high idle mod.,Sinister coolant filter, home built radio center console, Fumoto oil valve, Edge insight with SCT SF-3 in overhead mount,blue spring mod., BPD FICM, Derale deep cooling pan, BPD oil cooler, Jasper engine block & heads, ARP headstuds
DVCF450 is offline
post #4 of 5 Old 11-23-2013, 07:46 PM
asian195's Avatar
Quoted: 2 Post(s)
There are 2 fuses for the cig lighters. One for each port. But one is also power for your OBD port...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #5 of 5 Old 11-23-2013, 08:56 PM
have you tried using a test light to test the socket??? The outer ring is the ground and the center is the positive or use a meter to check the wires for voltage and trace it back.
2006 F250 PSD-Fabtech lift,King Coil overs,AMP steps,37's,some other bolt ons.
1965 Mustang Fastback-
Sound Decision Car Audio-MECP Certified
Ford Master Tech
iskwezm is offline
