batteries keep gettin drained - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-23-2013, 02:11 PM Thread Starter
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
alright so if i let my truck sit for 2 days my batteries will be completly drained and the truck wont start my batteries are brand new interstates im thinking its got to be a bad headlight switch because the marker lights on the licens plate stay dim when i shut my head lights off anyone ever have this problem?
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #2 of 13 Old 10-23-2013, 11:03 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
you check your alt volts when running cold and then warmed up? should be above 12.5 volts near 13-13.5 for healthy charge the oem ALT is pathetic, mine went out at 55k lol...
you could check the headlight switch too, my lights stay on for a second or two after i lock it then they all shut off, no dimming just off.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #3 of 13 Old 10-24-2013, 12:49 AM
Quoted: 818 Post(s)
Check your fuses for voltage and current at each one with the truck off to see what circuit is drawing them down.
Corey@CNCFAB is offline
post #4 of 13 Old 10-24-2013, 03:16 AM
Texas Proud
charlie.thomas's Avatar
check the ground from the battery to the body on the passenger side as well, mine had that symptom and I had a bad ground.
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #5 of 13 Old 10-24-2013, 03:40 AM Thread Starter
STRKTHS73's Avatar
well i know my alternator is good its brand new also and its my head light switch thats the problem checked it out last night the parking lights never really turn off even when you turn the switch off the lights will stay dim untill the battery is dead
06 F-350
edge cts insight
post #6 of 13 Old 10-24-2013, 04:23 AM
ShadowKev's Avatar
They don't turn off after 10 minutes either?
2007 F250 King Ranch STUDDED TUNED LIFTED
2016 Mustang GT
ShadowKev is offline
post #7 of 13 Old 10-24-2013, 04:32 AM
Heavy_GD's Avatar
Quoted: 1560 Post(s)
Feedback Score: 3 reviews
nice work on the diag.
GD
Heavy_GD is offline
post #8 of 13 Old 10-28-2013, 03:33 PM Thread Starter
STRKTHS73's Avatar
put the new switch in today solved the problem pinned out the switch on a little power hook up i made turns out the old switch had a minor short so it was constantly allowing a low amount of current through the parking light position
06 F-350
edge cts insight
post #9 of 13 Old 10-29-2013, 10:06 AM
Smitty02's Avatar
Quoted: 14 Post(s)
Nice work!!! now I need to checkm mine. It sits for a week or two at a time and this past weekdn it was a hard start I went to the battery voltage on my CTS and i noticed something strange.... When i first start the truck it sits at just under 12 volts for about 20 seconds then jumps to high 13s, between 13.6 and 13.9 After driving for about 10-15 miles the volts drop to around 13.1 to 13.5 the rest of the time. Is this delay at start up normal, is anyone else seeing this? Thx
2006 F550 Lariat Superduty
Link UltraRide System
4.88 Rear Gear
Banks Big Hoss Bundle
Banks intake
Banks Intercooler
Diesel tech "Bullet Proof" kit
Bullet proof EGR cooler
BPD External Oil Cooler system
Coolant filter bybass system
ARP head studs
40gal aft axle fuel tank
50gal TransFlow/Took box
Rhino lined bed
24K Air Safe 5th Wheel hitch
19.5 Alcoas with 225/70/19.5s
SCT SF3 3015 Tuner
Edge Evolution CTS w/EGT
4" Turbo Back Silverline Exhaust, 5"tip
Smitty02 is offline
post #10 of 13 Old 10-29-2013, 02:45 PM
ATV PRO 11's Avatar
Just watched mine via digital probe this weekend. Mine dropped from 12 (after just about draining batteries) to 9 for about a minute. Then same thing up to 13 and charged batteries. Glow plugs would be my guess, took a vid of it but haven't posted a question about it yet. I hear they can stay on for some time even after the light goes off on dash and truck is started.
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
