Turn Signal Issue - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-19-2013, 11:03 AM Thread Starter
Quoted: 392 Post(s)
Turn Signal Issue
Rear passenger side turn signal and brake light was not functioning properly. Initially thought bulb was burnt out so replaced it. Brake light now functions as normal but turn signal still doesn't work. Not sure if there was any fuses besides the main signal fuse. Checked that and it was fine.
Any thoughts on what to look at next?
2005 F-350 ext. cab long box, FX4
EDGE Insite CTS w/ fuel pres, EGT, and rear diff temp
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella ELC
Rotella T6 5w-40 Synthetic
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
268 000km/167 500 miles as of Jan. 1 2015.
Canadian Mind is offline
post #2 of 4 Old 10-19-2013, 02:12 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Multi function switch aka blinker switch
Sent from AutoGuide.com App
2000-7.3L is offline
post #3 of 4 Old 10-20-2013, 08:56 PM Thread Starter
Quoted: 392 Post(s)
Front and Mirror lights work fine, just the rear light doesn't flash. How would I go about digging into it?
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #4 of 4 Old 12-12-2013, 06:16 AM
ive got the same problem with my pass side front blinker. Its the multi function switch like was said. Gotta tear into the steering column to replace it
05 F250 4x4 cc sb Lariat: ARPs, zoodad, blue spring, sinister egr delete, banjos, sinister coolant filter, sct livewire with gearhead tunes; vivians looney on backup, leveled on 35" toyo mts, ranchhand legend front bumper, rotella T6, new oil cooler, zerex elc
troger11 is offline
