Instrument Cluster - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-15-2013, 07:58 PM Thread Starter
Kyle1228's Avatar
Instrument Cluster
I have a couple questions about the stock instrument cluster.
For one, I've had my truck for a little over a year now and I suspect (due to what looks like junk yard markings) that my instrument cluster has been replaced at some point.
So, I have a couple questions.
One, is it worth it to have it reprogrammed? Just in case it wasn't when it was installed?
Two, is there a cheap way to have it reprogrammed, instead of going through the dealer?
And three, what the hell is up with the temperature gauge in these things? It seems to make it's way up to the middle of the gauge when warming up but doesn't move AT ALL from there, no matter what temperature. I've had my truck up to 218F (which according to Ford, fuel cutoff starts at 221F) and the temperature gauge had not move and was right in middle of the gauge displaying proper operating temperature.
Kyle1228 is offline
post #2 of 8 Old 10-15-2013, 08:15 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Not sure about having it reprogrammed but the gauges in the instrument cluster are really just fancy idiot lights. Fueling is NOT cut at 221... I believe its 250*f. I've had my truck at ECT 230 and EOT 240 but I was pulling an extremely heavy load up a steep grade for 15 miles while staying at 60 mph. How do you know that you where at 218? You must have a monitor or some sort.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 10-15-2013, 08:23 PM Thread Starter
Kyle1228's Avatar
Are you serious?
I've read a few websites that state that normal operating temperatures are 190-215F, "service service" is 215-220F and "alarm" is anything above 220F, where fuel cutoff starts at 221F. I might be completely wrong but that's just what I read.
Anyway, I have a monitoring program on my computer that I have been using on towing trips, as well as every day for the past week because I just finished doing quite a few odds and ends on my truck and I just want to ensure that everything is running smoothly.
2003 F250 Super Duty XLT, 6.0L, 225K, Auto Fx4
Engine mods: Upgraded Garrett turbo, Blue Spring, Edge CTS, Bulletproof 5R110, oil cooler, EGR cooler & water pump
Future mods: MBRP 4" exhaust, Bulletproof HPOP & '08 Tow Mirrors
California Volunteer Search and Rescue Member
Daily Driver: 1999 Jeep Cherokee fully equipped for anything
Special thanks to NOR CAL EVI
Kyle1228 is offline
post #4 of 8 Old 10-15-2013, 08:27 PM Thread Starter
Kyle1228's Avatar
Haha, I just read a couple threads on operating and overheating temperatures and I feel like an idiot now. Sorry. The website that I read from must have been complete bogus.
So, no one else to comment on this instrument cluster reprogram?
Kyle1228 is offline
post #5 of 8 Old 10-16-2013, 03:09 AM
Quoted: 8 Post(s)
It's all good, what temps are you referring to anyway?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 8 Old 10-16-2013, 05:36 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1744 Post(s)
Feedback Score: 4 reviews
Question 1.....do the gauges work? then no not really...
Question 2.....not unless you have a friend with the Ford software and a programmer
Question 3.....Early99 had ya covered....other than the boost gauge (if you're 05+) the rest of 'em are pretty much fancy idiot lights, just like almost every other vehicle on the road. A monitor system like you have or a set of aftermarket gauges are the only way to get a "true" reading of your temps....if you have a trans temp gauge, wait until you double check that one
He had ya covered from the start man
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
post #7 of 8 Old 10-16-2013, 01:26 PM Thread Starter
Kyle1228's Avatar
Thanks guys.
All of the gauges seem to working. None of them or dead and all of the warning lights are displayed upon start up.
I'm thinking about purchasing the Edge Evolution II.
This product displays all of the temperatures that I want to be able to read and has a couple stock tunes that I can use, if needed. I will keep it in stock most for 99% of the time considering this struck has not had the head gaskets or studs done (I assume)
Kyle1228 is offline
post #8 of 8 Old 10-16-2013, 01:36 PM
Quoted: 8 Post(s)
Don't get the evolution... Your motor, trans and milage will hate you for it! For the same price you can get a CTS monitor, used SCT X3 or SF3 tuner and custom tunes which you WILL absolutely love. Contact Matt Robinson at gearhead automotive because I believe his SRL is just as safe as stock. You will actually run less boost but make about 120 more rwhp
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
