Intermittent power loss - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-13-2013, 08:04 AM Thread Starter
I have an intermittent loss of power to the gauges, radio, and doors on a 2004 F-350 6.0 diesel 4x4. It acts like a breaker is tripping but the only breaker in the fuse box is for windows only. Any help?
hwyhvy49 is offline
post #2 of 2 Old 10-13-2013, 11:14 AM
Quoted: 51 Post(s)
Not entirely sure what the issue is, but with something that is intermittent I usually start with ground connections and then look for shorts. The cab to frame ground is under the passenger side front door. Inspect closely and clean both connections. I even piggy-backed mine with #4 welding wire. The cab to block ground is from the passenger side rear of the cylinder head to just above the HVAC box on the firewall. Again, inspect and clean mounting surface. Battery to frame grounds are under the OEM air filter and beneath the passenger side battery box. Removing the front bumper is easy and really helps with accessing.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
