Which Wire Comes From Driver Door Ajar Switch - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-09-2013, 02:05 PM Thread Starter
I did search, but was surprised to find nothing. Sometimes, I would like my Excursion to act like the drivers door is closed when it's actually open. I know, crazy! I had the same wish for the rear lift gate...it was easy to remove the interior panel on the rear lift gate, locate the switches, the wires leading from the them, and install a switch to keep the dome lights off even when the lift gate is up.
I want the same for the driver side door but hoping I don't have to remove the door panel to find the right wire. Any one know which wire in the driver door comes from that switch? I can tap in either at the loom that spans between door and body or under the dash.
Thanks!
2005 Excursion Engine: EGR/CAT Delete, Innovative ECM Tune, PHP FICM Tune, coolant filter, stock TTY head bolts and Ford Gold Coolant. Suspension: Bilstein shocks; V Codes springs on front; RAS and Air Lift airbags over stock rear springs.
mmuthart is offline
post #2 of 4 Old 10-09-2013, 04:09 PM
Quoted: 7 Post(s)
Garage
Lite green with yellow strip & black wire on my 03!
Sent from AutoGuide.com App
rabpearson is online now
post #3 of 4 Old 10-10-2013, 07:49 AM Thread Starter
Thank You! If I remember correctly the wires from the switches in the lift gate were also lite green with a yellow strip. Makes sense I suppose...
mmuthart is offline
post #4 of 4 Old 10-10-2013, 08:46 AM
Quoted: 7 Post(s)
Garage
Yeah I have a F350 crew cab, but I assume the excursion and f series have similar door wiring. Good luck I've been trying to find out which switch is bad for quite some time hehe!
