Horn - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-18-2013, 10:29 AM Thread Starter
nate36's Avatar
Horn
My horn wont sound when pressed. I check the fuse inside the truck and it was good and no other fuse for the horn is labeled in the manual. is there any idea where i could look to fix this problem?
nate36 is offline
post #2 of 6 Old 09-20-2013, 07:42 PM
bigbear75's Avatar
i know when this happened on my 7.3L it turned out to be the contacts in the steering wheel were fubar'd
'05 F250 CC LB SRW 6.Bullet Proof
bigbear75 is offline
post #3 of 6 Old 09-20-2013, 07:53 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Common for F-250/350 etc horn to fail under the hood. Listen for the click of the relay inside, check for voltage in wiring harness outside. Horn is a pain to replace, under passenger side battery surrounded sheet metal, accessible by taking off fender and/or inner fender plastic. Great idea, right? Thanks, Ford...
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #4 of 6 Old 09-21-2013, 03:16 AM
elchaseo's Avatar
Quoted: 8 Post(s)
If cruise control doesn't work either it is probably the clock spring in the steering wheel.
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #5 of 6 Old 09-21-2013, 03:56 AM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
That will often make your airbag light come on or flash too.
IN-LAWS...
post #6 of 6 Old 09-21-2013, 11:32 AM Thread Starter
nate36's Avatar
awesome this gives me good places to look to see what it is glad i joined this fourm!
NATHAN ASHER
nate36 is offline
