4x4 light - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2013, 07:47 AM Thread Starter
4x4 light
2005 xl 6.0
Turn truck on 4x4 light comes on, along with my emergency brake light, low range, seat belt, and a door alarm blaring... took it to get scanned and nothing comes up..
manual t case put it in 4x4 and then neutral and it stopped... could this be a tcase or 4x4 sensor??
grizzly90 is offline
post #2 of 4 Old 09-12-2013, 08:07 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
The only place all those have something in common is the cluster IMHO
power is sent to all those lights as a check at key on but I am not sure what duration your seeing this anomaly ?
there is a cluster test you can run if you have the reset etc buttons
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 09-12-2013, 08:11 AM
ZMANN's Avatar
Bismic = ,,,,,,,
On the KR and Lariat models: You have to hold the Setup and Reset buttons at the same time, then turn key to on - you will see TEST and as soon as you do, let off the buttons and then start the truck - press reset to cycle thru all the options...
__________________
Mark
see if this applies IDK what you have ?
We Miss you Ronnie
ZMANN is offline
post #4 of 4 Old 09-12-2013, 08:25 AM Thread Starter
xl
I have an XL package.
