Overhead console/ compass issue - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-10-2013, 01:50 PM Thread Starter
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
My display works fine. Problem I'm having is it always shows "cal" on the compass part. I've went through the recalibration procedure a bunch of times and it might work for a day then the same thing. Anyone know if there is a sensor or module that goes bad causing the issue? I don't actually use the compass but it drives me insane to look up and see "cal" and not the direction.
dhanna6powerstroke is offline
post #2 of 12 Old 09-10-2013, 07:28 PM
Mine does the same thing...Seems like it works every once in a while, but says Cal the rest of the time. Interested to see if anyone has a solution...
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
post #3 of 12 Old 09-12-2013, 07:49 PM
Mud digger's Avatar
Subscribed, mine does the same. Pretty annoying......
David
2004 F-250 CCSB 4x4- Sinister Coolant filtration system, CCV reroute, 5" Flo-Pro Exhaust with a 6" MBRP tip, SCT Livewire TS
Mud digger is offline
post #4 of 12 Old 09-13-2013, 01:39 AM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Anyone?
post #5 of 12 Old 09-13-2013, 02:19 AM
usnavyad's Avatar
Feedback Score: 3 reviews
I know mine was acting funny so I took it apart. Mine was dimming then would not turn on at all part here's what it looked like
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #6 of 12 Old 09-14-2013, 01:09 PM
wngnt954's Avatar
Before my MPG indication was not working and now my compas is doing the same thing. The is a thread on resoldering some pieces on the circuit board to fix the MPG gauge. I believe it was the ones that have 620 or 680 in the first picture. I am planning to pull it apart and resolder the rest and hopefully that will do it.
Sent from AutoGuide.com App
The Family Truckster
wngnt954 is offline
post #7 of 12 Old 09-14-2013, 02:37 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
I don't have a problem with it not lighting up. I can read it fine, the compass just won't stay calibrated.
post #8 of 12 Old 09-14-2013, 03:29 PM
USAFBowman's Avatar
There's something about it in the owners manual.... I don't remember what it exactly says but you are supposed to drive around in circles to get it to calibrate
USAFBowman is offline
post #9 of 12 Old 09-14-2013, 04:56 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Yeah, I can get it to calibrate. The problem is it won't stay calibrated.
post #10 of 12 Old 09-14-2013, 06:42 PM
Term3's Avatar
Wonder if you do the general display fix if it would help?
Overhead computer Fix - Easy and it works
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
